TH400 & US Gear Overdrive
Discussion in 'The Garage' started by PsRumors, Nov 27, 2006.
  1. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    Kind of thinking out loud. '85 k20 Burb w/ 700r4. Am currently doing a 454 swap. This will be a tow vehicle and pack mule. I have read all I can read about the 700r4s and lack of abilities and strength, the 4l80e coversions and built 700r4s.
    With the cost of a 4l80e and then a controller you can be @ $4k quick. So, I was thinking, why not go to a TH400 with a US Gear Overdrive. Since it's a burb I have plenty of wheelbase, coverting to a 400 should be real easy, strength would be greatly increased, and would still have overdrive. Could do all this for $3k.
    This would also open my transfercase option up greatly.
    Thoughts?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im converting to 4L80E in my k5. ive collected most of the parts, and its not even gona cost me $1k, cheaper than the cost of replacing the existing 700r4 with a built one.
  3. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    No one else has any thoughts?
  4. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    wicked setup just sold a turbo 400 with that gear vendors over/underdrive for 1000.00
  5. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    boy did I miss out. You don't seen the US or the GV come up for sale often. Hope to use the US Gear though as it can be used in 2 & 4 wd.
    I wonder what the length differences are between a 400, US Gear, NP 208 as compared to a 700r4 & Np208.
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Tell me more about how a 4L80E with controller costs $4000.....???
    I played around with some of these ideas a while back. The GearVendors units are cool, but unless you can find one used they will NEVER be an economical alternative to a regular OD tranny. Last time I priced one they were something like $2500 for the kit.
    I thought 4L80Es could be had in the $2500 range, and the good GM standalone computer was another $700 or so??? It's been a while since I explored pricing..... :dunno:
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Last time I talked to GV @ SEMA (was a while ago) they didn't offer an OD to fit btwn the trans & transfer. They only offered one to hang off the back of the t/c.
    So the only way to get OD in 4wd would be to go to a divorced t/c.
  8. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    Well, I checked with Bowtie Overdrives which is what seems to be the recommended choice around here. $2k for the trans, $500 for the TC, $1100 for the controller comes to $3600 before shipping, before cross member, before etc. Close enough to $4k in my book to call it $4k. Used 4l80e at the local junk yard is $1500.
    At those prices is either really cost effective? Even if it is even money would either REALLY be cost effective. Which would be stronger?
    The GV wont fit between the tranns and TC but the US Gear does.
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    instead of gettin a 400+ od unit, why not just get a built 700? you can get one that can hold up to 600hp for like $1500 or so. if you did go to 400, u still gatta get 32spline t-case which is more money as well.
  10. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    True.
    Bowtie quoted me $2100 for a 700 and you can't tow in OD.
    In my thinking here this would be the strongest setup for the money. Or would it?
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i believe built 700 is the best way for the money. the 400 would rob more power as well and would cost more. plus everything will bolt right up, instead of needing new cross-members and such for the 400 combo
  12. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    You can have a few mods done to the vane pump(I think thats what its called) and a few other parts I cant remember to be able to town in Overdrive.
    Remington
  13. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Gripes! :eek1: That 4L80E does get expensive.....it's easy to forget that a TC is needed (which adds $$$), but their controller seems to be awfully expensive. I thought I'd read that the GM Performance computer was one of the better ones and was priced more like $700, quite a bit better than the $1100 that you are being quoted??? Either way, it's serious bank for that OD solution.
    I'm in about the same boat as you....I need an OD tranny for my 2WD Burb so that I can tow my 7500Lb trailer setup (I had assumed that I could ONLY do this in "D" not "OD").... yet still turn low enough RPMs with the OD when I wasn't towing to save some fuel and not be spinning my BBC so fast that I'm just wasting the life out of it.
    A really built 700R4 could be an option....but it would have to come from a shop with a rock-solid reputation, that would be willing to spec it for the type of application I'm considering. It's interesting to see that there are shops able to build them strong enough to even be able to tow in OD (not that I'd probably do it)....costs are still going to be pretty high, but the simplicity of not needing the computer is a pretty huge cost savings.
    :usaflag:
    The shops I hear a lot about are:
    California Performance Transmissions -> Art Carr's new shop
    Hughes Performance
    BowTie Overdrives
    What are some of the other "high end" tranny vendors worth talking to about this?? :dunno:
  14. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    What about Northwest Fab, don't they have a unit in the works for close to a grand?
  15. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    You talking about the "Black Box" product??
    Maybe if you flip it around and run in backwards, you could get OD out of it. But I'd hate to be running all my gears in OD all the time....I doubt you could shift it "on the fly" to only get OD once you were moving at high speed in 3rd gear..... :thinking:
  16. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    heres my thread from earlier in the year. after that thread i ended up going with 4L80E, yet to install it tho, but ive got the tranny, stand alone computer, and wiring harness.
    http://coloradok5.com/forums/showthread.php?t=181407&highlight=4L80E
    there are some other name companys that build 700r4's. theres some useful info in there. hope you can use some of it.
    i was checkin out mega monsters, on their site there stuff looked pretty solid
    im planning on running the black box with a 205, once i get everything, ill start a build up thread for the tranny and t-case swap.
  17. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    I have been reading till my eyes hurt :)
    I have found a 4l80e that is affordable, $900 to my door. Used of course.
    If....IF one was to go that route what I have not found is what it truly takes to mate a passenger side drop TC to the back of one other than Advance Adapters for another $600.
    Ideas muddybuddy?
    Thanks again.
  18. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    any t case can be made to work, given that its 32 spline... the easiest is to just use a 208/ 241 with the stock adapter... or a 32 spline 205 with a modifed 4l80e/ 241 adapter...
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    4L80E's came with 205's and 241's behind them, pass drop. any t-case can be mated to it with a 32spline input, and modified th400 or factory 4L80E adapter
  20. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    OK. That is easy. Then the crossmember just gets moved to the needed location? Maybe a 4l80e would easier than I thought.
