TH400 Vacuum source? ---NEED HELP QUICK! PLEASE HELP!---
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Jan 12, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I am going to be installing a TH400 in my 88K5 soon. Where is the best place to get a vacuum source so I can run a line from it to the tranny? Thanks!
    ______________
    I need to get this hooked up tomorrow, where can I get vacuume from? Please be specific! Thanks!
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s<P ID="edit"><FONT class="small">Edited by dawson444 on 01/19/02 10:38 PM.</FONT></P>
  2. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Re: TH400 Vacuum source?
    What tranny do you have now? Is it carburated or fuel injected. Look for a vacum port approximately the same size as the vacum modulator port.
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  3. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Dawson, I used the brake booster vacum after switching over to hydroboost. I made it a hard line down to the modulator. Worked pretty good.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  4. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    I have 700R4 now, and I have FI.
    Dawson
    Raleigh, NC
  5. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Can I put a T into the brake booster line and run vaccume boost and tranny off the one line? Is the fitting on the 400 ment for a hard line of a soft line? Thanks!
    Dawson
    Raleigh, NC
  6. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    i have a 88 th400 my source is a port just behind my tpi the same size as off the modulator!!!!
    NO LOCKER, STOCK GEARS, NO PWR BRAKES, NO POWER STEERING, NO PROBLEM!
    HIT IT FULL CHICKEN!!!!
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    And the answer is: Manifold vacuum. A port that comes directly out of the intake manifold will provide the signal that the modulator needs. You don't want to use ported vacuum from the carb or you'll confuse the heck out of the modulator. The stock configuration uses a hard steel line with a few inches of rubber tubing at each end.
    Don't forget that you'll also need to install the kickdown switch for the Turbo 400.
  8. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Where can I get manifold vacuum? I need help! Thanks!
    Dawson
    Raleigh, NC
  9. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    What does the port go to? Or what is it suppose to go? Thanks!
    Dawson
    Raleigh, NC
  10. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Dawson
    Raleigh, NC
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    There are ports on top of the intake, usually towards the rear. Look for a port that just feeds directly into one of the intake runners. That will be where you get full manifold vacuum. Edelbrock intakes usually have several intake vacuum ports already drilled and tapped. The largest is the feed for the power brake booster, but there are usually several others.
  12. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    I just tapped in to the brake booster line. I hope to know if it works at the end of the week.
    Dawson
    Raleigh, NC
