TH400 vs. SM465
Discussion in 'The Garage' started by bigburban383, Feb 9, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I am sure this has been brought up, but the search did not find it. What are the comparitive dis/advantages. I know a 400 you got to shorten your driveshaft, but do you really have to if you got a lift wouldn't it make up for that. What about driveshafts for the 465 conversion? Give me more /forums/images/graemlins/bow.gif
  2. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    sm465! I love em so much i had to have 2 /forums/images/graemlins/wink.gif They are bullet proof. No worries about overheating it like an auto. Driveshafts arent that dificult to find/make for a 465/205 combo. This going in your burb? If you choose the 465 let me know i might have some shafts that are the right length for that set up.
  3. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Yes I am going to put it in my suburban, only when i blow up my 700 because I got a bad feeling I am. The engine I am building is going to have 400 ftlbs of torque, that and its moving a suburban with only 4.10s. Not to mention the traction bars.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] Relax, a properly built th700 can take 400ft pounds just fine. I am right around 400ftlbs myself with 4.10's and heavy 35" boggers... and have had no issues whatsoever with my built th700.
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    465 all the way.. or 700r4.. if you have to have an auto, get overdrive.. a good BTO unit is about 1800 bucks plus installation parts, etc, and WELL worth it.. i love my 4 spd, well ok 3 with a granny.. even though i cruise the interstate between 2-3k..
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    2-3k is where you're supposed to cruise. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  7. Confedneck
    Nov 1, 2002
    5,236
    EHH..the motor makes almost NO power above 3800.. its almost like a diesel.. i really do wish it would cruise just a cunthair lower.. maybe 1800 or so.. 2000 rpms is about 65 on the speedo which i guess is 70 or so being i have 3.40s and 33s..
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    my only problem is with my daily driver I want a 5 speed. If I keep my burb and daily drive it I'm gonna upgrade to an NV4500.
  9. Confedneck
    Nov 1, 2002
    5,236
    if i could find a complete writeup with all the part numbers for an nv4500 conversion.. i would consider doing it..
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I went to work a couple minutes ago and I shifted down into 3rd 3 times looking for 5th gear. It just felt like I should be shifting. I'm just gonna look out for an NV4500 then get parts from Advanced Adaptors. Though I guess a 5 speed from a newer Chevy should work fine since they have 241 tcases.
  11. Confedneck
    Nov 1, 2002
    5,236
    i thought the newer chevys were nv4500s??
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    They are, I meant if I got one for a newer Chevy I probably wouldn't have a problem bolting my 241 to it with my present adapter.
  13. Confedneck
    Nov 1, 2002
    5,236
    ohh gotcha! /forums/images/graemlins/thumb.gif
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Maybe this is how we got so many posts?
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think 2200-2800 is ideal. Then again, all of my trucks have 4.10 gears and none have overdrive. C30 has 31.5s and the K10 has 38.5s.
  16. Confedneck
    Nov 1, 2002
    5,236
    hows that?? LOL /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/dunno.gif
  17. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Okay, I hope mine lasts, I am not going to baby it though(got to pull boggerless). I got a cooler on it /forums/images/graemlins/thumb.gif . It is supposedly a 700R4HD too, out of my K5, it had written on the top 700R4HD. I guess I can just start off in manual one so I dont blow up the one way roller.
  18. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    I wouldn't go with the 700R4 as these trannies have problems (same with the 4L60 and 4L80Es). I've got the SM465 in my 88 Chev reg. cab K30 dually (454 efi, w/4.10s) and my only complaint about it is I wish that it was a 5spd. because I can do 60 km/h (under 30mph) in 4th gear, so when it comes to highway driving the engine is revving pretty hard.
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    3.42s, 350, 31s, I'm in 4th gear by the time I hit 30 MPH.
  20. Confedneck
    Nov 1, 2002
    5,236
    hmm. bto, bowtie overdrives will build you a 700r4 rated for 600 hp... so they can be made strong..
    with 3.40s, 33s and a 350, i can pull the speedo to around 60-65 in 2nd gear and then shift into 3rd (shift pattern being L, 1, 2, 3)
