th400 whine and trouble shifting *Never mind, its broken*
Discussion in 'The Garage' started by BranndonC, Mar 4, 2006.
Transmission
  1. Change fluid and filter (Type F)
    0 vote(s)
    0.0%
  2. Change fluid and filter (Decron III)
    18.8%
  3. Put in lucas or transmission X magic stuff
    6.3%
  4. dont worry about it
    0 vote(s)
    0.0%
  5. i'm no help
    18.8%
  6. why isn't there video... i'm dissapointed
    37.5%
  7. naked?
    50.0%
Multiple votes are allowed.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    You can choose more than one responce to the poll.
    I searched and found that a lot of people have that problem until it warms up. But mine just started happening. What happened was 2 days ago I put it in 4 :1 low to see how it drive, the transmission obviously whined when I did that. But yesterday I took the truck out, and it whined the whole time, and shifted too soft into drive and reverse. This morning (cold out) I warmed up the engine, then drove it out, still whining, drove down the street, turned around and came home, whining the whole time. Theres no water in the fluid, but it looked a little dirty, do you suggest a fluid change (about 2-300 miles MAX on it)? also I read on here that type F is less slippery, so it shifts firmer, and that a couple guys here run it. what do you think would help?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Maybe somebody installed a cam gear drive while you were sleeping. I sometimes get the "there's something wrong with that truck!" look when I fire mine up around non-gearhead types.
    Seriously, I bet that a new constant whine will ring an instant bell with one of the tranny gurus that lurk around here, and more info probably couldn't hurt. Fluid level OK? Was it a new torque converter, and if it wasn't, how old was it?
  3. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    refresh my memory, please... what's the history of the transmission? I'd pull the pan and check to make sure the pickup tube didn't fall off and has the O-rings in place then if it needs a new filter do it at the same time. if after that it still whines then :dunno: maybe plumb in a pressure guage to make sure you're getting adequate line pressure.
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i bought it, then I installed a shift kit and had it rebuilt, so its basicaly a fresh transmission. I haven't pulled the pan since I installed it, So i'll do that this weekend, and post what I find. Thanks for the advice
  5. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ARGGGGGGGGGGGGG DAMNIT!! It just went out. Damn damn damn. I cannot afford a new one. Bah :( Reverse kinda works, no forward gears what so ever. even in 4:1 low it doesnt even pretend to want to move :(
  6. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    pull it apart and post up.
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    you know what! That's what i'll do! Thanks, i've always been afraid to takle a transmission, but what do I have to lose now! I'll proably pull it tomorrow and get started on a new doubler mount too. Thanks for the push, lol
  8. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    and I'll make a video tutorial on how to rebuild a th400 :)
  9. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    That will go great with all previous video tutorials of why its broken now :p:
  10. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i have a manual i scaned on how to rebuild the 400 if you would like a copy let me know
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i would like a copy! lol i'm going to get all the refrence materal I can. Thanks! my email is at the link in my sig, I dont want to type it here because bots come in and spam me! lol
  12. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    ok i will send it, its going to take a few emails becasue it is pretty large in size
  13. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks! i'll read those this evening
  14. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    its all sent now
  15. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks alot! It'll definately help :)
  16. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if its whining all the time, sounds like the pump. not building enough pressure let the clutchs slip too much and burned them up.
    the th400 is an easy transmission. good luck with it.
    also if you have 300 miles on it, can you get it warrentied threw who built it?
  17. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    the video sounds like a cool idea. Especially since I'll be having to do the same thing shortly:D
  18. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you didnt even have to say you were going to make a video, it was expected...:D
  19. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I second the pump was makeing the whine. and cooked the clutches.
  20. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Umm...
    Not if the guy who rebuilt it has watched the "burnout" videos....:whistle: :tongue1:
    My guess would be the pump too,unless the filter came off, or plugged up suddenly,and starved it for ATF..had a TH400 in my GTO that did that after I had to rock it from D to R a million times after I got stuck in my sisters yard after a snowfall...it whined like a siren ,and was lazy going into drive and reverse,especially on cold startup..the pan was full of clutch material,looked like coffee grounds!..
    I changed the fluid and filter,and it never acted up again..had I driven it farther than the 10,000 miles after that,I would not have been suprised if it did though..that tranny saw a hard life,lots of burnouts and beatings!..
    You might not be so lucky..the torque of a 500 Caddy will toast pretty much ANY tranny...even properly built ones with coolers,etc..just the nature of the beast...:crazy:
