TH400 ?
Discussion in 'The Garage' started by blazen91, Oct 2, 2004.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    On the side of the 400, there is a plug for checking line presure. How much presure should I have?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Neutral - Brakes applied - engine at 1000RPM: 55-70psi
    Drive - Idle speed: 60-85psi
    Drive - Brakes applied - engine at 1000RPM: 60-90psi
    2 or 1 - Brakes applied - engine at 1000RPM: 135-160psi
    Reverse - Brakes applied - engine at 1000RPM: 95-150psi
  3. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    You are the man. More info than I was expecting. Thank you. /forums/images/graemlins/waytogo.gif
  4. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/thumb.gif
