TH475 what is it
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Apr 21, 2001.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I have heard of a th400 but to day I was reading four wheeler and the said some thing about a th475 I have never heard of one and would it work in a blazer
    also I have heard of an NV4500 would this be a good tranny for a blazer?
    thanks
    [​IMG]If you want to run cool
    you got to run on Heavy Heavy Fuel (106.1 RDU)
    <A target="_blank" HREF=http://www.trailblazer90.coloradok5.com>http://www.trailblazer90.coloradok5.com</A>
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The 475 I think was in the moterhomes.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails<font color=blue>
    <font color=blue>Wayne<font color=blue>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, it was used widely in motorhomes.
    Its the same thing as a TH400, but the differences are the planetary gears. The 475 has straight cut gears compared to the angled cut on the 400. The straight cut ones are much stronger than the angled cut ones.
  4. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    The NV4500 is what I am planning on putting in. There is a few people who have them. Do a search on them. If you ask me they are great for getting the best of both worlds. You get overdrive and a granny gear.
    When all else fails... Check the blinker fluid.
    78 K-5
  5. James90
    May 18, 2000
    986
    Rocky Mount NC
    is the th475 the same size as the th400?
    and is the NV4500 a manul or an auto?
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It's pretty much the same thing as a TH400 (same case, just stronger guts like the other post said). Seems like I've seen those things with a disk tranny brake too. I wonder if it could be adapted to use as a parking brake on a 4WD? Probably not since it would need to be moved to the tcase but, it would be sweet with a divorced case.
    Hmm, visions of a FI Pontiac 455 with a TH475 (475 guts in a Pont. TH400 case) using the tranny disk and a divorced 205...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  7. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    the th475 also came in some C 60 trucks and some earlier diesel applications. Very strong.
    your right. I don't understand the jeep thing!
  8. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    A 475 will work in any thing you can put a 400 in. When I bought mine it had a big drum brake hanging off the back of it. The trans shop had to change the out put shaft. I put it in my wifes 2500 4x4 Burben. The straight cut first gear whines alittle, but it has been a great trans.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
