TH700 Shifts Firm Real Firm!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87BrnRsd, Jul 2, 2003.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Some of yall have probably read my other post about putting an engine in my 87 K5. Well, now that its in, I have gotten to drive it around. It is a FI350, with 139,000 miles on it, and is now and has been completley stock all of its life (That is going to change as soon as I get that echobit flip, 14 bolt, and 35's in though /forums/images/graemlins/wink.gif). My question is, is really firm shifting a sign of the transmission going out? I pull it down into drive and its smooth as can be, but when I get the speed up, the shifts between gears is horribly firm. Jerks the whole truck. I am going to change the fluid and filter soon, but was just wondering if this is a sign of the trans going out. I think its either that, or it was just re-built really tightly. Thanks.
    -Harrison
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    did you adjust the TV cable? if there is too much pressure it will shift really hard.
  3. 87BrnRsd
    Apr 21, 2003
    2,457
    No, I havent thought of that. Thanks.
    -Harrison
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    If you figure out how you made that 'mistake', let me know. My T-700 is way to lazy....
  5. 87BrnRsd
    Apr 21, 2003
    2,457
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif I'm not sure which is worse. If you rode in my truck, you would be surprized the transmission doesnt fall out every time it shifts.
    -Harrison
  6. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Don't waste too much time waiting to adjust that TV cable.....from what I've read, if it's out of adjustment it will destroy the tranny very quickly......
    /forums/images/graemlins/eek.gif
  7. 87BrnRsd
    Apr 21, 2003
    2,457
    Oh, I'm not. The blazer is not being driven everyday, and has only been driven maybe 6 or 7 miles like this. I am going to pick it up and bring it home today, and will adjust it before I drive it. Thanks.
    -Harrison
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    too tight of a cable will cause tranny to wind up far high into each gear before shifting, also same thing will occur if cable is not connected or if something under the pan is not connected right, quicker shift is alwasy better than low rpm shift, but theres a such thing as too much RPM before shift in most cases.
    to adjust 700r4 TV cable you open throttle by hand all the way and then depress the cable housing sleeve lock button at the intake manifold bracket, just behind it towards rear of truck, then pull cable housing behind the bracket back til cable is tight with throttle still wide open by hand, then let go of button and then let go of throttle
    now go test drive, if you did it right or if tranny is not boogered up then all should be great in tranny-land
  9. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i was told to adjust the cable you push in the tab on the back of the bracket and push the adjuster all the way to the firewall. then you open the throttle all the way with the gas pedal. when you do this you should here the adjuster click as it adjusts out to where it should be.
  10. 87BrnRsd
    Apr 21, 2003
    2,457
    Thought I would post a follow up for yall. The cable was already adjusted all the way to the firewall (causing the firm shifting), so I adjusted it back a little, and got it shifting about perfectly. Thanks for the help guys. /forums/images/graemlins/thumb.gif
    -Harrison
