Thang Dang Rear Window!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RockaFella, Oct 22, 2002.
  1. RockaFella
    RockaFella Registered Member
    Sep 12, 2002
    63
    South Carolina, Rockhill
    Iv Taken It Apart iv Rebuilt it IV DONE IT ALL and IT GETS HALFWAY UP AND GET STUCK! I need 2 People 1 to Push the Button and Another to Shake the Glass anyway to solve this Problem!? /forums/images/graemlins/angryfire.gif
  2. Grim-Reaper
    7,385
    Atlanta
    Window tracks are rusted out in the bottom. The regulator is jamming on itself because the window is at the wrong angle. Dealer can get you the tracks for a decent price in about 48 hours.
  3. RockaFella
    Sep 12, 2002
    63
    thats just it theres no rust! we have redone the whole thing the window works fine when the Back Cover is off ( one facing inside) It works Fine Im thinking of just Leaving it down BUT It sucks exhaust in The Back Maybe i should just put in a Rag Top and Put Gutter Guards on the side /forums/images/graemlins/rotfl.gif
  4. Grim-Reaper
    7,385
    Atlanta
    That's odd then. Mine had the exact symptoms and the tracks were the culprit. Got about half way up and stopped with a thud when the track attached to the widow hit the regulator.
  5. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    ditto on that one, im having the same problem. let me know what fixxes it
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. RockaFella
    Sep 12, 2002
    63
    Grim Take a look at my Idea on the rag Top I think ima just do that and not worry about the window
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Did you ever have big loads on the inner side?
    Mine did and that arched the inner side and it was rubbing on the window, and finally it got so bad it hung on ti and that is when I noticed it. There is a plastic guide that will snag. Just check that there is nothing close enough to be the culprit. Aslo, did you adjust the rails to have it centered and straight up? if it a little cockeyed it could do that, but I guess it wouldn't work with the cover off then... well check for clearance.
  8. Great78burb
    Great78burb Registered Member
    Sep 24, 2002
    28
    San Diego, CA
    You might try taking the screws for the access panel out 1 at a time and cycling the window each time. Mine was hanging up on one of the screws on the inside. It drove me nuts trying to figure it out! /forums/images/graemlins/burb.gif
  9. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    or you could do what im doing..take the back of a truck cap door...just take the door from one..and put it on the back of the k5 cap..find one the right size and that matches that contour of the cap pretty good..paint it to match..and it looks pretty damn good...also locks..lot more durable than glass which could just be smashed..i just think the k5 should have came with on to begin with! and you can put some insulation on it too..just my .2
  10. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    no offense, but the K-5 did come with it to begin with, the first gens all had it
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    oh yea i forgot about that..lol..i was more refering to the 2 generation ones..but true the old ones did have that...i think its a lot better than the glass to!
