Thankk God, she's runin' COOL!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bowtied, Aug 14, 2001.
  1. Bowtied
    Bowtied Registered Member
    May 21, 2001
    69
    NC
    Thankk God, she\'s runin\' COOL!!!
    Wow, what a headache this has been! After changing everything in the cooling system$$$, she is FINALLY running cool. I won't make this a super long story but I want you all to be aware of this incase it ever happens to you, could save you $$$.
    I went to a rad shop as a last ditch effort to see if he could run some nuclear radioactive super dooper chemical through the block cause I was sure that's what it was. The dude had me remove the t-stat and run it without it. I thought he was on crack because it was the third one in a weeks time. Anyhow, there was no coolant up in the intake minifold where the t-stat goes. We ran it with no stat and she was cool. Threw the stat back in, and presto...150 degrees with the A/C on!!!! I'm blown away, the thing must have had some air trapped in it from being open so much...just like my baby, one good belch and everything is all better!
    By the way, hats off to the cap'n, I think he actually suggested the burping idea a few days ago. I thought I had all the air out, guess not!
    I guess it should actually be a little warmer than 150, but I'll just shut up and color!!!!!
    Thanks dudes for all your info on this one!
    Andy
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Re: Thankk God, she\'s runin\' COOL!!!
    Great news!!!
    In search for the sound of frying bacon!! [​IMG]
    3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Hey at least you have a bunch of new parts you wont have to worry about for a while!! [​IMG]
    CONGRATS on FINALLY getting the problem solved!
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Cool beans!!!! Just think, you got all new parts (no headaches for a while). Also remember to flush the system yearly to keep scale buildup to a minimum. You wouldn't believe the extended life you will get from radiators, water pumps, thermostats, and heater cores.
    Glad your finally running cool.
    If you didn't build it yourself, how can you call it yours.......?
  5. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    I personaly was begining to think it was possed with a radiator demon and was going to suggest we perform an exorcism LOL
    glad to hear you got the thing cool [​IMG]
    good luck on your trip
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  7. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    hey congrats... [​IMG] man after all that??? I'll bet you're happy after having the thing cooling finally!!
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  8. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    Cool!!! (pun intended)
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  9. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    just a thought but maybe you should post the shops name in case anyone else in the area has a problem. I learned along time ago plug the good guys and destroy the bad guys. helps all involved,maybe even you down the road. Glad to hear its solved!!!
  10. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Congratulations!! Glad it wasn't something serious, and now you have a virtually new cooling system!
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
  11. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Congrats Bowtie... I'm glad you nailed the problem down. If I had a dollar for everytime someone said there was a problem and it was air in the system. I have become very good at refilling most motors to minimize air bubbles. You might want to look into getting a thermostat housing w/ one of the air bleeders in it from a local parts store before your next cooling system service [​IMG] Buyt very glad you have a cool running truck again and no damage was done.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  12. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    WOW..........[​IMG]
    <font color=green>Joe Angelicchio
    <a target="_blank" href=http://community.webshots.com/user/jangelicchio>http://community.webshots.com/user/jangelicchio</a>
    Lisle, Ontario, CANADA</font color=green>
