That's what that noise was!
Discussion in 'The Garage' started by pvfjr, Jul 27, 2004.
  1. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    That\'s what that noise was!
    I was plauged for months by this horrid sratching sound, slowly progressing over time. Almost like a fan on a schroud. It was driving me crazy, cause I couldn't find it for the life of me, it was randomly intermittent, and I had eliminated almost everything. Then a friend made a comment about my "polished balancer" and I began to wonder why it was so clean... /forums/images/graemlins/yikes.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Re: That\'s what that noise was!
    So what, something hit the bottom of the x member and then the balancer rubbed a whole in it??? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    Wow! now thats a nice mod u got there. So, whats wrong? the motor mounts loosen and she tilted forward or what??
  4. el diablo
    el diablo Registered Member
    Jun 12, 2004
    30
    Mt. Home Idaho
    I would say broken motor mounts.
  5. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yeah, the motor mounts were completely shot! New ones really lifted that engine back up. /forums/images/graemlins/thumb.gif
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    DAYUM! /forums/images/graemlins/yikes.gif Did you pull the belts off the balancer pulley and check for play? How much did you grind off the balancer it self? If it's been rubbing for awhile, I'd be worried about that front main bearing. With the mounts broken and the engine sagging enough to rest on the balancer, something had to support all that weight. /forums/images/graemlins/dunno.gif
  7. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Holy crap i bet thats exactly what the noise was on my truck then too! Kinda sounded likt there was a wire hanging down and hiting the fan right? Mine usally only did it taking corners and mine was a longbed pickup too. /forums/images/graemlins/doah.gif
  8. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I don't think that would have been a problem. It tended to do it more when I was compression braking real hard, or putting a load on the p/s pump, or alternator, anything that kinda make the engine tweak a little. I got crate engines in my sights anyway, this one will work until it breaks.
    What do you guys think about that crossmember? It also has a crack on one of the ends, and now this. Should I get one of those Missourri Offroad Outfitters crossmembers? I was thinking about that, but I also want to do that ford shock tower thing, and wouldn't want the crossmember to be in tha way of that.
  9. dyeager535
    26,977
    My dads truck did that too. When you changed the mounts, did you closely inspect the pieces the mounts bolt to?
    Both mine and my dads were cracked in that location. (either the crossmember or the metal pieces bolted to the crossmember)
    His '74 was in much worse shape crack wise than mine.
