The Best Dana 60 Question??
Discussion in 'The Garage' started by 77blazin, Dec 19, 2004.
  1. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    I have a question for all the beefed up axles out there...
    What is the best Dana 60 to get for a 78 blazer, I mean whats the best one?
    The specs on the 60 like 3.73 gears or anything better?
    And do you have to get a 14 bolt corporate with the same specs as the front?
    What about Disk brakes for the rear do I really need it?
    I have someone here in Hawaii that is selling a set for $2500 with new seals and an optional disk brake conversion on the rear, is that really a good price?
    Or should I get one from the junkyard that is going for $750 a set stock and still on the truck?
    Please help!!!
    Mike
  2. chromewontgetyouhome
    chromewontgetyouhome Registered Member
    Aug 1, 2004
    69
    Big Island, Hawaii
    Im in the same boat as you. I want some one tons for my 1/2 ton short bed. Ive called all the wrecking yards here on the big island, and no one has a wrecked 1 ton. Ive been keeping an eye out for a broke down cucv in some ones yard. With all the military bases on Oahu, you shouldnt have a problem finding an olive drab chevy. If you ever on the big island let me know, I have a ton of ulua poles and some killer spots!!!
  3. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    'best' dana 60 is definitely 81 and up (larger inner axles)
    definitely try to find a military CUCV they have 4.56 gears and a factory detroit locker in the rear
    you don't necessarily have to get a 'matching' 14 bolt, but you must match the gears front to rear
    rear discs are not necessary, but a very good upgrade because they decrease weight while improving efficiency.
  4. 77blazin
    Mar 31, 2000
    394
    Honolulu Hawaii
    Reeser,
    Thanks for the info, A seller had told me that I needed a matching set of axles, meaning matching gears, I didn't know that and needed info here, just to be sure.
    Grah (NOCHROME..)
    You should have junkyards in your area, if you can't find a CUCV and your neighbor ain't going to give it up, you're best bet will be the junkyards, certain pickups and comercial flatbeds heavy duty vehicles have straight axles, I was lucky enough to find one and its on a container!?
    Check with "Island Previews" www.islandpreviews.com and check out "Drivetrains" 3 1-tons showed up with one being a matching set.
    And that Ulua fishing thing, what kind poles you get?
    I'm a heavy fisherman to, I just got too much reels and not enough poles to fill them.
    Maybe we could hook up when I come down and do some baitcasting with a night of sliding baits.
    Then we can talk about papios and restoration of our blazers.
    Its good to see another Hawaiian pounding this site, I thought I was the only "Poi Pounder" here.
    Tight Lines!
    Mike
  5. chromewontgetyouhome
    Aug 1, 2004
    69
    Big Island, Hawaii
    Thanks for the link!!!! Got some searching to do for that infamous dana 60!!!
