The best STARTER on the marked?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 75blazer454, Nov 8, 2002.
  1. 75blazer454
    75blazer454 Registered Member
    Oct 1, 2002
    27
    Norge, oslo
    whats the best starter for my 7,4 bb i can get?
    i have broken 2 starters in 3months. grr!
    GM the way to go?
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I don't know if they make one for the 454, but I love my Powermaster XS Volt. It is about half the size and more than 40% lighter than the OEM and it has 4:1 gear reduction. Anohter GREAT thing is it is all aluminum and GUARANTEED against heat soak!
  3. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    any other good starters??
    I need the BEST!
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    yah, get an AC Delco and be done with buying starters. I went through what you're going through now. Tried numerous Pep Boys, Autozone starters and they all failed. Put an AC Delco in and I'm still running it almost 3 years later.
  5. ratlover
    ratlover 1/2 ton status
    Aug 5, 2002
    215
    Peorial IL
    Whats breaking on them? The nose? Is it aluminum or castiron(the nose)? Do you have the support in the back? Is it properly shimmed? Is your motor timed right? I bet its not a problem with the accual starter
  6. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    suport in the back, timming ok, the last one broke the nose.
  7. ratlover
    Aug 5, 2002
    215
    Peorial IL
    So it aint kicking back....wered the other one break? Is it aluminum or castiron nose?
    BTW this wasnt because of breaking just because they are junk and stopped working. Went through 3 parts ameriaca starters and got tried of replacing them(they were under waranty) and swapped to a delco and no problems
  8. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    ok, maybe its kicking back whats wrong then.
    i now the timing is correct.
    i think its cast irond.
    kristoffer
  9. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I agree with Waxer, and I had the same problem. Went thru 3 starters before I got an AC Delco. No more problems.
  10. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    okey i think i am going for an ACdelco but maybe the powermaster if they have it to 454.
    anybody now the spesifications for acdelco starter?
  11. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    it sounds like it's not shimmed properly? i know on a sb chevy you shim it to 1/8" gap (i'm pretty sure, it's been a while). i'm not sure about a big block, but i'd be willing to be that it's the same amount?!
  12. Skigirl
    Apr 2, 2001
    2,563
    The part number for the AC Delco that went on my 76 K5 was from GM dealer: PN 1876555
  13. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Tilton mini-starter! /forums/images/graemlins/thumb.gif
  14. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    A 454 uses the same starter as a SB. Same bolt pattern, same ring gear or flexplate diameter.
  15. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i just put a starter off of a 1970 LS7 corvette on mine and it still has a lil bit of trouble. i have the remote solenoid, but i like to run a lil advanced. so till i spend the money on an XS starter, ill retard a lil and see how this one holds up to the mud and [censored] that i go through with the snorkel. o i paid $31 and it has a lifetime warranty
    NITRO
  16. 75blazer454
    Oct 1, 2002
    27
    Norge, oslo
    are u 100% thats it is the same Same bolt pattern??
    a starter for a 350 will it fit`?
  17. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have a lifetime waranty one from NAPA and its been going strong for a while now...
  18. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I was EATING starters on my 7.4.....1 a year!!!
    Last year I picked-up a Duralast starter from Autozone......its still going strong....
    They have a LIFETIME warranty!! Less than $30 too!!! /forums/images/graemlins/thumb.gif
    If you don't shim correctly your DOOMED!!
  19. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    hey, i just got mine form summit. its a powermaster gear reduction. i love this thing. somewhere around 342 ft. lbs. of torque and it never gets heatsoak(i do also have the remote solenoid) id reccomend these in a heart beat. but, it was also $230
    NITRO
