The best tire size for stock or 2"-3" and 4" lift?
Discussion in 'The Garage' started by pitbulls'n'blazers, Jan 20, 2006.
  1. pitbulls'n'blazers
    pitbulls'n'blazers Registered Member
    Jan 18, 2006
    67
    Missouri
    I would like to know what is the best tire size for my stock K5,and the best tire size for a 2"-3" and 4" lift.
    Thanks!
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Depends on if you want to cut the fenders or not. With 4 inches you can fit 33's for sure with out rubbing. 35's will fit but they will rub so you may need to do some minor trimming. This also depends on the width of the tire and rim size.
    Now if you wanna do some :hack: :grind: :weld: then you can fit whatever size you want. :saweet: :woot:
    All that being said, check out the search feature, this has been covered several times in the past.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    My stock 90 runs 33's with just minor rubbing of the inner wheel well on the back when twisted up. My built 90 runs 37's with 3" of lift and no rubbing.
  4. pitbulls'n'blazers
    Jan 18, 2006
    67
    Missouri
    Thanks for the info,and I thought this topic has been talked about before.Sorry if I repeat some questions,I'm pretty new hear,and I'll search a little more before I post.:doah:
  5. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    i had 33s for a while on my blazer, ran stock susp, 2", and 7"...rubbed no matter how much lift i had, but i had to try hard to get it to rub with 7". Lots of people run 35s with 4", just trim up some, don't do anything too extreme and you will be fine. Im running 40s with 5" rt now, so you don't have to have a ton of lift to fit a decent sized tire.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    go 49s and Rockwells, and never look back.
