The cure for the dreaded D60 DW?
Discussion in 'The Garage' started by thatK30guy, Dec 22, 2002.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Found this pic on the PBB.
    [image]http://www.pirate4x4.com/forum/attachment.php?s=&postid=1009090[/image]
    Here's the link to the details: Kind of long, but very good and informative stuff.
    Here is another link to the PBB site: D60 rear steer project.
    Read this and check out the details about the knuckles and the elimination of the plastic kingpin bushing (hint: uses a tapered roller bearing instead). /forums/images/graemlins/thumb.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Aren't you banned from there?
    Unless you did some spoofing.
    -- Mike
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, I'm banned as a member, but I'm browsing as a visitor. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Holy Crap that was long, it took me almost an hour to read, I personally think that I could put my money somewhere better, but hey, pretty cool! I LOVE to over built crap, but that's insane!!!!!!
  5. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Well I read all 10 pages (WHEW!) but I can't say that I saw a solution to death wobble......? /forums/images/graemlins/frown.gif
    I did see a "solution" to an excessively large bank account though!!!! That guy should have no such problems after building up that D60!
    WOW
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    I saw the solution to the DW in the plastic bushing eliminators...those steel thingies with the tapered roller bearings on them.
    Would also require a new machined steering arm/cap to run this setup. /forums/images/graemlins/cool.gif
  7. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I talked to "WB", the guy that built the upper bearing set up, and he said that his bearing design only works with his fab'd knuckles ($1500 /forums/images/graemlins/eek.gif). On top of that, the bearing set up does not have any provision for a seal so it is completely exposed on the bottom side. He said to keep pumping grease through it and keep it ot of mud and sand - read: competition only.
    BTW - I ordered 2 of those cool gusset kits from him.
  8. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    You know, I'd never considered that the entire upper nylon bushing is only really held in place by that spring cup assembly.
    I suppose it IS a logical assumption that with a LOT more load on that spring from the heavier tires/wheels....the spring is going to be pushed out of position a lot more easily.
    I'm not sure that I understand enough about WHY is was designed that way in the first place (as opposed to a tapered bearing) but I still wonder if it would make sense to try to "shim" that spring for more pressure....or if there is a spring from some other application that is similar in size, but with a much higher pressure (some kind of BIG valve spring?, etc)
    Unrelated factiod: -> Timken bearings are made in my home town of Keene, NH. I think they used to be called something else when I was a kid, though.......
    /forums/images/graemlins/smile.gif
