The Dana 60 Definitive Guide to alignment specs...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Apr 29, 2003.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I started this post cause all I could find were bits and pieces of information out there on what the alignment specs should be with a D60.
    Here's what I've found so far, but I'd like anyone to chime in and correct this and/or add to it.
    Caster = 4-8 degrees positive
    Toe = 1/4" Toe In
    Does anybody have anything to add or correct with this? Thanks...
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Are you sure you didn't mean caster=4-8?
    Camber shouldn't be more than a degree or 2, but Caster should be in that range, less will make it wander, and more will make it shake.
    /forums/images/graemlins/thumb.gif
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    When we talk about toe-in and stuff does the tire size matter much or is that 1/4" a certain distance from the king pin centers?
    Rene
  4. Waxer
    1,857
    Long Beach, CA.
    When talking about toe in/out, this is what that means...
    I've read on previous posts where the general consensus was the optimum setting is 1/4" TOE IN. Looking at that image, you can figure out what that means.
  5. Waxer
    1,857
    Long Beach, CA.
    Yes, Caster... thanks for the clear up. /forums/images/graemlins/smile.gif
  6. Waxer
    1,857
    Long Beach, CA.
    Although I haven't measured it yet, I can visually see that there is substantial TOE OUT on my D60. I still have the stock tie rod it came with and I didn't mess with its settings.
    I would guesstimate it at having a good 1/2 or 3/4" of TOE OUT. Once we get some good replies on here about what the setting should be, I'm going to adjust mine myself.
    When I did the crossover on the D44, installed a RockRod at the same time, I set the Toe at 1/4" Toe In.
    It drove pretty damned good with that setting. Although I did nothing to check for Camber or Caster.
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    I guess I wasn't clear. Imagine setting the toe-in to 1/4" with 31's on the truck. Now bolt up some 42's...then measure your toe-in. It'd be substantially more than 1/4". Is that 1/4" setting a ballpark? Should larger tires be toed in more?
    The tire size can vary a lot, and saying 1/4" toed in without providing a generic datum is nearly useless IMHO.
    I guess my question is this. Should larger tires (heavier, wider, more rolling resistance, and more leverage on steering parts) be toed in more than 1/4"?
    When I had my 36's on the truck I had it toed in 3/16" and it tracked pretty good...very little wandering. My D60 with 39.5's is toed in 3/16" and I don't think it's enough. Both measurements were taken at the tread face of the tire.
    Rene
  8. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    WHAT ??
  9. Waxer
    1,857
    Long Beach, CA.
    I gotcha Rene, yeah I'm not sure myself hence this post. The 1/4" that I stated was used with 33's and it seemed pretty good. I still have those 33's so I'm going to run with 1/4" again and see how it goes.
  10. 82TOYLB
    82TOYLB Registered Member
    Nov 28, 2001
    61
    Sacramento California
    I understood what Rene was saying, I do agree that the toe in is not helpful unless we have a specified point to measure from and more information on what larger tires require. Could the measurement be from the front edge of the rim/wheel? Then just let the tire, whatever size it is ride where it is. I.E. larger tires with more toe in and smaller tires with less.
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    IE, at what distance from the centerline of the spindle is the magical 1/4-inch measured? The tread of a 28 inch tire would only be 14 inches from that centerline, while the tread of a 44 inch tire would be 22 inches from that centerline. Measure the toe in at the tread of both tires, without making any change to the tie rod, and the toe in would appear to be a higher value for the 44 inch tire. (That's what Rene was trying to say...) /forums/images/graemlins/wink.gif
  12. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    That's what I meant...maybe some people that run the larger tires on the street could post up how much toe-in they run and where it is measured. I'm thinking that 1/4-5/16" toed in at the tread face of my 39.5's would be closer to ideal than the 3/16" I have right now. I just don't want to go too far and scrub the tires any more than necessary...
    Rene
  13. Waxer
    1,857
    Long Beach, CA.
    Yeah thats a good idea.
    I was kinda hoping there were some ASE certified mechanics here that do alignments daily to let us know where the standard measurement is. It might be the backside of the rim. I know on smaller passenger cars they mark the center of the tire all the way around and go from there. I'm sure since its all computerized they prolly just enter in the tire size and the computer does the rest.
  14. Executioner
    Feb 22, 2000
    1,530
    Yes it is the centerline of the tire, but for a K5
    as it left the factory. Put larger tires on and
    ect. you will need to redo the geometree.
  15. Waxer
    1,857
    Long Beach, CA.
    geometree? /forums/images/graemlins/smile.gif
  16. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    Geometree...a large ungainly looking tree with branches at all sorts of weird angles. /forums/images/graemlins/rotfl.gif
    Rene
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Rene
    OK I guess there is no ASE certified people here since I didn't see any response to this yet.
    The correct way to measure toe in is by angle not distance.
    Different makes need different toe in measurments, usually depends on how much the drag will push the tires out when driving it.
    a long tie rod would stretch more than a short stubby one on a sports car, plus the bigger the tire the harder the pull.
    On the blazer with stock tires the recommended angle is 1-2 degrees on each side, the bigger the tires the closer to 2 you need.
    I can do the math and convert that to measurment for each size tire but I am sure you can do the same.
    1/4" is in the ballpark for up to 33".
  18. Waxer
    1,857
    Long Beach, CA.
    Gotcha...
    So for something in the realm of 38.5's, it'd be better off going to 3/8 or possibly 1/2" toe in?
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    Rene
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    Ohhhhhhhhhhhh, I get it..... geometry!!! /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  20. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, i know how you set toe in toe out, but how do you set castor camber on a D60?
    this is a much needed post and i am glad somebody brought it up as i am finishing a rebuild on my D60 now.
    grant
