The definitive guide to a 14 bolt swap (14BFF)
Discussion in 'The Garage' started by zakk, Jul 31, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    The 14B swap is any easy and bulletproof upgrade to any vehicle. The greatness that is the 14 Bolt Full-Floater (Forthwith known as 14BFF) axle is we documented. It is so strong, and so cheap to purchase, rebuild, and upgrade that there are more than a few Ford's and Jeep's that run this monstrosity of an axle.
    To convert your 1/2 vehicle to 3/4 or 1 ton, you will need to find a 14BFF. Prices will vary from $0 - $300 for the unit, depending on your part of the world you call home. Most agree that $100-200 for a good unit is reasonable.
    Where do you find such an item? A junkyard, your neighbor's rig in his driveway (they are that common), or Salvage shops. There are many to choose from but we will assume you will be looking for a pre-AAM 14BFF (70's-80's) for this article.
    Variations of the 14BFF:
    K30,C30: narrower spring perches that will have to be rewelded, 2WD versions will also need new shock mounts. *Pre 1973 vehicles: This is a direct swap in, with the above mentioned notes (Beast3888)
    K20,C20: The K20 is a bolt in for post 1973 Rigs. Get the 8 lug conversion pieces for the front while you are at it. C20 will only need the shock tabs reworked
    Van 14BFF: The most desirable version. Specs differ depending on the year, but they are wider than a truck 14BFF so your track width will be the same (or closer to it)
    Gear ratios are between 3.73 and 4.56, with 4.10 being the most popular by far. A Deee-troit locker is the only available locker for the unit, and is substantially cheaper than any other locker out there. In addition, the strength of the 14BFF and the Deee-troit = bomb proof, IMHO. I don't carry spare anything for my 14BFF (which is equipped with a Deee-troit, also) save a driveline u-joint.
    Swapping the Unit it:
    If you were lucky enough to get a K20 14BFF: remove rear drive line, disconnect e-brake, remove axle, install new axle
    If you got any other 14BFF, you will most likely need to reweld the spring perches. IMHO, this should be done by a well trained welder. A professional if you can find one. Now is also the time to look at making any pinion angle adjustments.
    To remount the shocks, use your imagination. What I did won't work for 95% of you, so I won't even bother. As your having your spring pads rewelded, talk to your welder about some simple mounting tabs.
    To utilize your existing (stock) driveline, a conversion driveline u-joint must be used. Napa #348 u-joint is needed if you are replacing a 12 bolt, a Napa #447 is needed if you are replacing a 10 bolt.(Bowtiered & Beast388). A good driveline shop will be able to help you on this, or call Steve at South Bay Drive Line (408-995-6000) who seems to have every U-joint memorized and is cheaper than most mail order outfits. Tell him Phat zakk sent you. He'll then know your working on a Blazer of some sort.
    E-brakes are on a case by case basis. Mine work, but they aren't as tight as they used to be. Adjusting them is a fo-sho!
    Other issues to consider:
    The 14BFF is also affectionately known as the land anchor. while doing your swap it is a good idea to lop off 1" of the lower lip. this leaves well over .3" which is plenty of metal. Some have gone as far to make the 14BFF a 13BFF and turn down the ring gear and then plate the bottom. Remember: Ground Clearance: every 1/4" counts!.
    Also, the 14BFF is an 8 lug axle. It can be converted by use of adapters (one company is Echobit.com) to make it 6 lug, or you can swap 3/4 outers from a K20. You deiced what is best for you.
    And with that, I'm going to treat myself to a frosty Diet Coke. Good luck.[​IMG]
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thanks for the write up /forums/images/graemlins/thumb.gif I'm sure it'll help out alot of people who are intrested in this mod. /forums/images/graemlins/thumb.gif
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Thanks Zakk...you must have been reading my mind /forums/images/graemlins/thumb.gif
    Now can you do one for a D60 swap /forums/images/graemlins/ignore.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I haven't even finished my front Diet Coke!
    i think there is one, to be honest....
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    now that i actually think about it, a D60 swaps right in! all you need is a steering block (assuming you have a 4-6" lift) and new u-bolts. Brakelines hook right up (or alteast mine did, and all Dana axles use a standard driveline 1310 u-joint so there your driveline and yoke stays the same.
    in some cases, your front driveline might need to be shortened do to the pinion "length" of the D60 compared to the D44. i don't know the exact measurment.
    D60's are also 8 lug, so you save the cost of converting your D44 or 10B front to 3/4 ton 8 lug stuff.
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    zakk, to add to your uber-definitive 14BFF swap article, the Napa #348 u-joint is needed if you are replacing a 12 bolt, a Napa #447 is needed if you are replacing a 10 bolt. /forums/images/graemlins/thumb.gif
    K20 14BFF's are bolt in for 73-up trucks. Those of us with '72 and older will need to move perches (as I had to do) or find a 1-ton 14BFF.
    Great Write-up! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    credit where credit is due /forums/images/graemlins/thumb.gif
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I believe there is a spool available out there for a 14FF.. Sandy Cone I believe has one as well as someone else i think...
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    got a link?
  10. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Not to split hairs, but my stock d-shaft ('90 Jimmy) takes a 3r u-joint, not the more popular 1310/1330/1350 units you find. I searched around and couldn't find one through Spicer, Neapco, NAPA at the time. I had one (actually several) made at Birmingham Leaf Spring. Just a point some people may want to be aware of before undertaking the swap. Not a big deal but could stall a project by a few weeks.
    I searched on google to see if a part number for this converion exists, but wasn't able to come up with anything.
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I thought the one from Sandy Cone was a custom unit designed for 46 spline axles? /forums/images/graemlins/1zhelp.gif
    Rene
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
  13. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Zakk,
    I'd like to say thank you very much for pretty much making this issue an idiot proof one for me. I have now added this to my Favorites as I'm sure I'll look at this quite often. I ssen to be loosing my memory in my old age /forums/images/graemlins/grin.gif
    Anyway, I'm sure your work in writing this article will do alot for any other mechanically challenged people like myself /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i have a 14bff out of a 76 k30 camper special sitting in my back yard. just went out and turned the wheel to figure out what the gear ratio was. i got a little over two revolutions on the pinion yoke with one rev of the tire. whats the lowested the 14 came with? unless im counting wrong, thats way less than 3.73
  15. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Good write-up. You may want to add that a detroit will not fit a limited slip carrier, so if you plan on a detroit, find an axle with open diff.....
  16. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Good point, but also add how to tell the difference between a open carrier and limited slip, for those who don't know.
  17. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Good write up! One thing to change - The K30 spring perches are wrong also and need to be redone, they are backwards from the ones that we need. </font>
  18. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    Thanks for taking the time to do all of that. I am sure it will be really helpful. /forums/images/graemlins/smile.gif
  19. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Zakk,
    Maybe list the actual spring perch widths?
    I think the relevant ones are 42.5" (for almost everyone)....and 40" for the 1st Gen guys.
    Also, POFF wrote up a really nice document about not only the 14BFF swap but also 8-Lug front converions too. He never posted it on CK5, but had offered it to anyone who asked him via email. I got a copy and though it was well written. It had the complete procedures, as well as recommended tools, and parts sources for the small parts you'd need. Might be worth checking out if you're TRULY going to be "THE MAN" who writes the definitive 14BFF swap page.
    BTW -&gt; Mad amounts of this /forums/images/graemlins/thumb.gif for even trying to do a project like this one!
  20. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I thought of something else that you can add, but it will take some research. The castings for the center chunk on the 14b changed at some point, the later ones seem to be thicker on the bottom. Mine is from an 87 and it doesn't have a 1" lip on the bottom, it's only like 1/2", so I know that they changed at some point. </font>
