the difference in rims...
Discussion in 'The Garage' started by silver, Sep 11, 2002.
  1. silver
    silver Registered Member
    Jun 8, 2002
    72
    Dallas Texas
    I'm looking into getting some new rims, should get 15x8 or 15x10???
    thanks,
    Grant
  2. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    what size tires. and for looks or wheeling?? personaly i like anything in a 12.50 and wider on a 10" wheel. or if it's gonna be flexing a lot a 12.50 on a 8" wheel is good because it's a little narrower and will "stuff" better in the wheelwell. but for looks a 10" will give it that wide, mean look. if its anything smaller than 12.50 wide, 8"
    keith
  3. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    That all depends on the size tire you plan to run. It also has a little to do with how you want it to look.
    anything larger than 12.50 wide you would most likely be better off with a 10in or larger rim.
    Anything 12.50 wide and smaller on 10in rims takes a little more pressure normally to keep the tire riding right and you also can't air down quite as much.
    Right now I have 32x 11.50 on 10in rims and it makes them appear slightly bigger than they really are but are actually a little shorter than if they were on an 8in rim.
    Hope that helps...
