The Dreaded Hot Start Problem
Discussion in 'The Garage' started by Don, Jul 16, 2002.
  1. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Doe's Anyone have, or used one of the Lightweight, Gear Reduction Starters, on a Big Block?
    The reason I'm asking is I have the old O.E.M. Starter on the 454, and with the Heat now in the N.W. I'm having the Hot Soak, Heat Stroke Effect on the Starter.
    Just wondering if the Mini, Gear Reducted, are any Better?
    Thank's in Advance, Don H. /forums/images/icons/confused.gif
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    Have you tried the remote solenoid yet? That usually helps about 75% of the problem...it works well enough for mine anywyas and my truck would barely turn over when hot before.
    Summit sells the solenoid kit for 30-40 bucks...
    Rene
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Just use a remote solenoid!! Just get a Ford style solenoid and kiss the heat soak problems good bye! I did it and have never had a problem since! I got my kit from a place called M.A.D. Enterprises, was like $30...add in the cost for some quality 1/0 cables and you're set! I use a stock starter, no need for any expensive stuff in my case...
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Yes I already have the Remote Solenoid, on the Firewall. Still have Heat Stroke prob.
  5. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    FIrst I did the heat sheild thing.. worked MOST of the time. Then I got the $170 mini+gear redution started. I haven't looked back since. This was on a 402 with headers.
    The warrantee on these things SUCK! It's like 90 days... /forums/images/icons/mad.gif
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Thanks Topoff, I just wanted to know if they were worth a Damn, or not! /forums/images/icons/blush.gif
