the dummest thing about my tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tmaxxer9, Apr 24, 2003.
  1. tmaxxer9
    tmaxxer9 1/2 ton status
    Feb 12, 2003
    195
    Minnesota
    ok here it is. first of all you have to know that my tranny would not go in to gear for the life of me, so anyway. today my uncle stopped by to look at my tranny, and he didn't see anything wrong as far as leaks(i have a huge puddle of tranny fluid on the floor in my garage and no clue as to where it came from), pumping, and shifting. well we loosened one of the coolant lines a little and started the truck to see if it was pumping. it was. so then i mentioned that i dropped the pan once and maybe a little air got in the tranny. so then we proceeded to bleed it, and after a little while it kicked right in to gear. /forums/images/graemlins/thumb.gif
  2. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    Problem solved! Feels good, eh?
  3. ut77gmc
    ut77gmc Registered Member
    Nov 29, 2000
    65
    Salt Lake City, UT
    ????--bleeding the tranny.....could you please elaborate for the unedumacated???? Nothing came up in the search
  4. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I've never heard about bleeding a tranny... please explain
  5. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    it is kinda like brakes, you know how if there is any air in the brake lines they won't work very good. well same thing with the tranny. the only thing is i have to find out if it is holding tranny fluid.
  6. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    I think we were expecting an explanation of the steps you performed....
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The problem with that is that trannies have vents so the pressure never builds up enough to rupture the seals, thus it has air in the system and no way to rid the system competely of air(which doesn't matter anyway). Whereas a brake system must have zero air in it...I'm confused...
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    bleeding a tranny /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
  9. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    What kinda tampons do you use for a bleeding th 350 as compared to say a 400, or 700R4... /forums/images/graemlins/wink.gif
    *Fumes desperatly looking for the"I'm serious smiley"and not finding it...* /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  10. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    careful of that toxic shock syndrome.
  11. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    ok if trannies have vents then why did i have to get the air out of it in order for it to work. i even put in 2 qts. and it still didn't kick in. but then when my uncle loosened on of the cooling lines and had me start the truck to get it flowing and get the air out. after he tightened them back up i shifted it into gear and it jumped right in. so if the is never any air in the tranny then why did bleeding it help???????????? /forums/images/graemlins/confused.gif
  12. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    I think this might a random coincidence.....Trannies normally have air in them....I don't know why bleeding would help. The only time I've heard of something similar to 'bleeding' a tranny is flushing it completely to replace all the liquid if it needs replacing. Air shouldn't matter. I think you just got lucky.
  13. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    how did i get lucky
  14. BlazinRojo
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    lucky in that it just happened to fix itself.....maybe the process of bleeding changed something, but getting the air out wasn't it. I don't really know what could have been wrong or fixed it.....but bleeding the air out isn't it.
  15. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    IF? All trannys have vents /forums/images/graemlins/smile.gif I have no idea why it starting working after you disconnected the cooler lines, but I know that disconnecting the cooler lines until there is a steady flow of ATF does not remove all air from the tranny...
  16. gumneck
    gumneck Registered Member
    Feb 6, 2003
    89
    VA
    Probably had a piece of trash stuck in a valve and it either dislogded itself or maybe your uncle beat the helloutofit with a hammer while you were out of earshot. Most likely trash b/c mine got hung up and went from no problem to no shift in two days.
    Bleedin or not your good to go. And that is impotent.
    Tom
  17. gumneck
    Feb 6, 2003
    89
    VA
    misspell. Impotant.
