The electronic window supposed to roll up and down with key?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82Jimmy, Aug 4, 2000.
  1. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I have electric windows, and the back window will roll down but not up! Is it supposed to be that way?
    <font color=blue>If its too loud, your too old.</font color=blue>
    http://82Jimmy.coloradok5.com
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Would say key switch is bad. Will it roll up with switch inside the cab?
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    My window goes up and down with the key. I think its supposed too. You may have a misconnection in the switch. l
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Sometimes the cable gets loose on the way down inside the tailgate. Just give the tailgats a few good smacks a little to the left of the center of it and it will usually work. Did that make any sense?
    90K5
  5. 82Jimmy
    Jun 9, 2000
    702
    the switch in the front works, its just that about every day i use the electronic key on the back.......its really slow, noisy and pops.....my other windows are really slow to. any suggestions....? And 90k5...i read that like 10 times..and all i got was a headache! [​IMG] thanks for the help so far! I want my windows to go really fast!
  6. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    See the old contact vrs the new? I have 3 more pictures showing how to get there.
    <font color=blue>Espen88k5 at:http://www.espen.coloradok5.com</font color=blue>
  7. Espen88k5
    Feb 19, 2000
    981
    Norway
  8. Espen88k5
    Feb 19, 2000
    981
    Norway
    Take off the power-motor cable. unscrew the window from the regulator. 4 bolts. Then slide the window out half-way and rest it on some gardenfurniture. The regulator assembly is 4 bolts around the edges of the base. Take it out as shown here:
  9. Espen88k5
    Feb 19, 2000
    981
    Norway
    The key-switch base is then two nuts from inside. The white plastic retainer keeps the contact from sliding off..
  10. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    To get the windows to move faster lube tracks, I use white lithium grease in the spray bottles.
  11. Espen88k5
    Feb 19, 2000
    981
    Norway
    I redid this opperation because I replaced the key-cyllinder last year. And for a year now, I have had different key's for the doors and the tailgate. I decided to reuse the old keyswitch. and just replace the coroded plastick part. It's not a big job, I did most of it while "mom" was shopping. And Erlend, my son was a great litle helper:
  12. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    you can save one step in that process by leaving the window and regulator attached and sliding the whole unit up/out.
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  13. 89K5
    89K5 1/2 ton status
    Jun 14, 2000
    134
    Maryland, PA on Weekends
    Espen88K5, Thanks for the post. My switch is gone too.
    Nice pics, get 'em started young!
  14. 82Jimmy
    Jun 9, 2000
    702
    Wow! Espen, did you replace the switch? Or just connect check the connections? Thanks for the really detailed pics...and also does your window work a lot better than before? Thanks guys! I took that access pannel off before and sprayed a can of wd40 in it....made it stop squeeking so much, but thats about it.
  15. Espen88k5
    Feb 19, 2000
    981
    Norway
    My window worked from the dash-switch but not with the key. This was back when I bought the truck. I took it apart and found the melted/coroded spring-switch. I ordered a new GM-key-switch from the dealer and it came complete with a new key. Now I had 3 keys. One for the doors, one for the ignition and one for the tailgate. I left it like this for a year but I knew I could have just replaced the white plastic-housing you see inbetween the pliers in the first picture, and kept the original door/tailgate key ...so I did it again.
    If your windows are slow it could be your motors are old and tired but it can just as well be dirty, sticky old grease mixed with wd-40 and rust/road dust. If you take it apart you will now what to do.
    BTW, Anyone else having trouble uppgrading their CK5 web sites?
  16. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    I was just thinking, I really have no idea at all, but if your windows are slow, could it possibly mean that the power going to them is low? Does anyone else think that could be a possibility for the slow windows? I am not sure, I was just thinking.
  17. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    It could be low power. I'm no electrical wiz, but I need to have the truck parked and rev the [censored] out of the motor to get the window up. Mine too only works on the dash and not the key. Great pictures though. Looks like you have a pretty good assistant there.
    Canuck
    Go Wide or Stay @ Home
  18. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I have left this post s few times before, it is easy to repair the back switch....if interested just email me for a detailed report.
    Eagle86K5@aol.com
