The finished/Mounted roof rack
Discussion in 'The Garage' started by cbbr, Dec 18, 2004.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    My first welding project 1/2 square tube bent with a pipe bender ans BFH in my carport. MIG welded at every seam. 3/4 square tube bottom support. Fits flush on the roof down the midde (4 rails) Truck did not have a factory roof rack so I mounted it through the roof and roof supports with 6 grade 8's (and plastic shims), rubber and fused washers and a ton of silicone 2. Walked on it and it feels very solid. Gonna mount the spares (two full size - H2 wheels are cheap) antennas (cb&phone) and gas/water cans today. :xmas:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Looks pretty good.
    Did you weld on some mounting tabs for the spare tires and water cans or are you going to use tie down straps?
  3. cbbr
    Jul 17, 2004
    14,681
    Working on it now - using the mount from inside the truck with a plate and welding the nut to it. That way I can move them around if I need to.
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    good job :waytogo:
  5. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    looks good. i wish i would have made mine bigger. i hope you dont to alot of trail riding and stuff with low branches. mine gets hung up on everything. good lookin rack though. how much does it weigh?
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    very nice, biggest roof rack I've ever seen.
  7. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Nice job!:cool1:
  8. sublmnl1990
    sublmnl1990 1/2 ton status
    Nov 8, 2004
    419
    Virginia Beach Va.
    How much does it weigh? Can you post some pics of the mounts you fabbed? I want one of these for my SUB! Looks Great:waytogo:
  9. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Now you need to mount some light.
  10. cbbr
    Jul 17, 2004
    14,681
    Thanks for the complements - In answer to the questions -I took out the headliner and drilled through the roof supports in the back. The middle rails sit flush with the roof, so it is bolted flush with some of the "camper strip" used between camper shells and truck beds in between.
    The front "mounts" are bolts through the roof supports and then through plastic shims I got from the "specialty bin" at Lowes. I just ground the shims down to fit. They sit on rubber washers toped with regular washers.
    Nothing techincal, but it feels very solid and was a lot cheaper and easier than the alternatives. Cost about $15 for the hardware and $125 for the steel/wire/primer/spray paint. God (and my wife if you asked) only knows how many hours, but it was my first welding/fabrication project so I took my time.
    The roof supports sit flush with the underside of the roof and I used large washers there also. Because the rack sits flush, the load is spread over the whole roof. The rack weighs about 65lbs.
    As far as trees - it will be interesting but the trips that I have planned right now are to AZ and the beach.
    Light is on the way as soon as $$$ permits.
  11. bradym
    bradym Newbie
    Dec 18, 2004
    3
    Louisiana
    That's the biggest piece of junk I've ever seen. You should have had a friend help you with it ;-)
  12. cbbr
    Jul 17, 2004
    14,681
    I would if I had any helpful friends that weren't jeep guys.:whistle: Glad to see that you got registered. T is registered as BURBicon.
  13. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Looks very nice. That's about the size of a rack I would rather have. Let us Know how the mounts to the flat part of the roof stand up to a load.
  14. cbbr
    Jul 17, 2004
    14,681
    If the roof can hold the load, the rack mounts should do fine. With all of the room in the Burb and my M105 I will probably never load the rack down like some guys. Just a great place for spares and junk.
  15. BURBicon
    BURBicon Registered Member
    Dec 11, 2004
    78
    Sunny Phoenix
    ROOF RACK???? You mean "tree catcher"!! (good 1)
    That may very well be the biggest roof rack that I've ever seen too. I thought mine was big. It comes down to, if your rack is too small, you'll wish it was bigger, but if its GIANT, you can throw your buddy's jeep on top when it breaks down.
  16. BURBicon
    Dec 11, 2004
    78
    Sunny Phoenix
    p.s. tree cather
    Your little white truck don't look so little any more. I remember when mine looked like that, but that was a lotta hard mile ago.
  17. cbbr
    Jul 17, 2004
    14,681
    Watered it and left it in the sun. It grew.
    The tree catcher comment is only funny if you are not my neighbor with the low limbs that are being torn out of the tree. Looks like I build a duck blind on the roof everytime I back out of the driveway, but the Burb is winning so far.
