The gas tank puncture problem.
Discussion in 'The Garage' started by DavidB, Jan 8, 2007.
  1. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Buddy of mine (ARQ) once had a piece of gravel get between his skidplate and his gas tank and then when he hit a boulder, it pierced the tank. He LINE-Xed the replacement tank to help prevent that in the future. Anyone else have any ideas? What if you put a piece of foam in there so a rock couldn't get in there?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Put the tank in the bed, or weld a huge skid plate below and up the sides of it.
  3. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Yah...you'd have to completely enclose it to keep gravel out entirely. I kinda like my foam idea. See any flaws?
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    foam sounds like a good idea, won't protect against boulders...
  5. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Not so worried about the boulders...they might dent it, but not puncture it unless there's a little rock in between the skid and the tank to poke the hole.
  6. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I second, third, fourth, whatever:D The foam idea. I would however paint the tank, or coat, for rust because water WILL:mad: get in between the foam and tank creating a rust promoter:doah::bow:
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    he said the tank got line-x'ed, that would prevent the rust.
  8. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    You're right. Rust isn't too much of a prob here though. If I LineXed it, I'd prolly have 'em do it heavy enough to resist the gravel and not do the foam.
