The HispanicPanic has a Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HispanicPanic, Oct 30, 2001.
  1. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    ok here it is a friend of mine has an 85 K5 and the rear right of the truck sits lower than the rear left so he changed his leaf srings and got rid of his blocks, still the prob. continued so he changed his body mounts and did a bodylift while he was at it and still the prob. continues so we think its the frame could there be something else we might have missed?
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    sure he didn't park on the curb[​IMG]
    did you check the shocks, also i have hear that if you tighten the leafs when they are hanging it will put some torque on the leaf and will tend to force it up a bit. loosen all the leafs at the eye when the blazer is on level ground and check it again.
    bodymounts...
    also check for broken/damaged bump stops, that could be a sign of a very hard landing and bending the fram.
    de casualidad no esta gordito tu amigo...
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    This is what ya do to fix it.. Find the biggest jump you can and launch that blazer. Sure fix there!
  4. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Someone once said that about mine but i never noticed it then I figured out it was my Fat a$$ that caused it to lean...I guess the old spings dont like 275lbs on them
    I'm not late im on Central Standard Time
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    none of my trucks sit perfectly level. Never have found the cause either. Just one of them things that makes you go "hmmm".
    Still Poundin' "pavment" after all these years!!! [​IMG]
  6. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Panic....
    I've had this problem... Traced it to the right rear spring perch on the axle being bent into a "convex" shape instead of flat. So, when you tighten the springs down, one spring automatically gets "sprung" kinda backwards from the start - so truck sits crooked!.... I actually added one extra leaf to the right side spring pack to make mine sit level...
    Marv
  7. Grim-Reaper
    7,385
    Atlanta
    What if the left front was sitting high. Or the right front was sitting low. [​IMG]. maybe the problem is in the front not the back. That said. They wifes 79 sits pretty level but my 75 doesn't.
    Get out a measuring tape and start checking stuff. Measure from the top of the axles to the frame. Find common points on the frame and measue (in a X likfe front right intersction of corss memeber to transfercase mount on driver side) to check for a bent frame. Like I, in a round about way pointed out...the problem can be in the front but more noticable in the back. The rear springs are much softer than the front so you will see a problem frame the back. Also since the rear has so much over hang it's more noticable.
    Women dig dents and flat paint!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    This is the HispanicPanic on ScoobyDann's PC he didnt want me to log him out cuz he forgot his password again so im showing up as ScoobyDann
    arq: ese cabron esta mas flaco que la chingada asi que eso no puede ser.
    marv: how the hell are you? as far as the spring pech he had the prob. with his 10 blt and 14 blt so i guess he'll just have to add one more leaf to that side
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
