The hugest TBI conversion write up, EVER
Discussion in 'The Garage' started by Mastiff, Aug 9, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I don't know why I did this write up... I just had so many pictures. This is the full chronicle of my carb to TBI conversion using a kit from customefis.com.
    We're talking 50+ pictures. /forums/images/graemlins/deal.gif
    http://www.taildragger.info/K5/TBI/
    Let me know if something doesn't look right or is technically incorrect, or whatever.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'll use this thread to talk about something I've been wondering about. Losing EGR. Whats the advantage or disadvantages of it? I lost it on my 85s carb motor but that was just to clean things up I had no alterior motives on that one. I'm thinking it will simplify things in the intake area and maybe wiring but hurt me on emissions. Am I correct in these thoughts?
  3. k-5 jimmy fan
    k-5 jimmy fan Registered Member
    Jul 27, 2004
    28
    "I don't know why I did this write up... I just had so many pictures. This is the full chronicle of my carb to TBI conversion using a kit from customefis.com.
    We're talking 50+ pictures. /forums/images/graemlins/deal.gif..."
    /forums/images/graemlins/waytogo.gifExcellent write up, IMHO you were clear & concise as to problems encountered and solutions for same.
    Also, appreciate very much your compiling the required components & sources for same if choosing to go the non-kit route.
  4. Grim-Reaper
    7,385
    Atlanta
    zero gains on a FI engine to loose it. EGR closes at full throttle and it closes at idle. only times it is on is cruise and part throttle.
    If it's not installed and functioning then a custom chip will have to be burned. The ECM knows when it supose to be open and it is expecting to see a mixture change at the O2 sensor. So it may actually cause more epense to loose it then to keep it.
  5. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif Great article, I have been waiting for a good TBI swap article to come along and finally it is here /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I need a new chip anyway, building a 383 with plenty of mods.
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    In theory EGR should gain you some hwy mileage since it basically decreases the displacement of the engine. No one I've ever talked to about it lost hwy mileage by disconnecting it. I suspect that lacking it the PCM will hard code an EGR fault of some sort. That might screw you if you have emissions testing to deal with since it will turn on the Check Engine light.
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Going from a carb engine, you'd need a computer controlled EGR, I think. I'm not certain of that. If that's the case, then you can either make a non-EGR prom or get the correct EGR. I got rid of mine just to clean things up, and I figured there's no way it can make things run better. It's always on the list of things to check out when the motor isn't working right.
  9. Grim-Reaper
    7,385
    Atlanta
    Nope. THe early EGRs pre OBDII are just regular old EGR's. They have a Solonoid inline on the vacuum. No problem to add it.
    Here is a little tip on hunting that will save you a ton of frustration. Find a TBI off a 87-89 454 with the adaptor. It's spreadbore pattern and will bolt right onto your Quad intake.
  10. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    That's cool. I didn't realize the 454 TBI's bolted to the spread bore intake. What is that giant hose coming from the adapter?
  11. Grim-Reaper
    7,385
    Atlanta
    On the 350's like used inthe story there is a preheat passege in the intake. It prevents freeze up when it's cold. On the 454 since it uses the stock intake there is a gap betweent the throttle body and the intake. That hose is plumbed into the heater hose to heat that adaptor to prevent freeze up.
    I have this bypassed on my 88 Burb because the other hose is a factory only $70 heater hose. I didn't bother to get a barbed adaptor and the winters are mild here. didn't have any problems.
    That is the one I bought to convert my 75 Jimmy. It came off a 89 454 Sub. In 90 they went to a new intake like the 350's. So this is a little bit of a rare part. /forums/images/graemlins/ooo.gif
    I'm selling the 75 and this FI is destined to end up on my 1970 Pontiac LeMans now. /forums/images/graemlins/grin.gif
  12. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    You did a great job on the write-up. Good wording, advice, descriptions, thoughts, and good photos too. I hope soemeone does something similar for big blocks, I would like to move away from carburetion myself. Looks like the rest of the rig is pretty sharp too! Good luck with the final details!
  13. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I wonder if I'll have problems in the cold then... My Edelbrock manifold doesn't have the coolant passage I don't think. Are you talking about icing on the butterflies mostly? I had this some with my carb since I have the open element air cleaner without the heated air ducting. If nothing else, I hope the computer will open up the IAC and keep me from stalling until the engine warms up.
  14. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks. /forums/images/graemlins/thumb.gif
  15. pizpump
    pizpump Registered Member
    Sep 15, 2004
    16
    Mastiff, what experimentation did you use to determine what gas line was feed, return, & vapor?
  16. dyeager535
    26,980
    On my TBI senders, only the pickup is submerged under about 1/2 tank. Pump might block trying this, but if you could force air back through to an almost empty tank, you would hear the pickup (feed) line when it started bubbling.
    The return line dumps about midway down, and vapor doesn't extend into the tank at all.
  17. pizpump
    Sep 15, 2004
    16
    Problem for me is that both lines are the same diameter, both lines come into the tank very near each other, both smell like gas, etc. It's basically impossible to tell them apart by eye. There must be some test that will give me a definitive answer. Guess I'll probably end up dropping the tank to be on the safe side. /forums/images/graemlins/crazy.gif
  18. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    I counted 49........jk Awesome job on the swap. Personally I had tbi and it sucked so I swaped to a late model fuel injected motor. But I am sure its loads better than the old rochester carbs, plus mine had a bunch of mangled egr tubing and quite a few sensors that had gone bad, needed a tune up, had 180k miles on it, and only got about 9 or 10 mpg. I am also positive that yours runs alot smoother and gets a little better mpg than I did. /forums/images/graemlins/waytogo.gif
    Remington
  19. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just find the line that feeds into the TBI and trace it back to the tank
  20. pizpump
    Sep 15, 2004
    16
    You misunderstand. This is a carbed truck that I'm converting to TBI. The fuel lines are both "dangling" at the tank. There is nothing to trace back to the engine.
