the last fairlead thread i promise
Discussion in 'The Garage' started by NEK5, Jun 2, 2006.
can you use the same roller fairlead you use with cable for synthetic winchline?
  1. YES!!!
    9 vote(s)
    42.9%
  2. NO!!!
    9 vote(s)
    42.9%
  3. i dont give a chit because i dont even have a clue(and i`m nekki)
    3 vote(s)
    14.3%
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    once and for all....can a roller fairlead (the same one used for cable) be used with synthetic winch rope??????
  2. greenbeater
    greenbeater Registered Member
    May 24, 2006
    19
    michigan
    i have seen it done but have heard that its not a good idea. althogh i know that i would use a NEW one for rope as an old on from wire could have a bur or something that could cut your rope
  3. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    I wouldn't, even if the rollers were undamaged. Synthetic winch rope works best with hawse fairleads... it doesn't need rollers, and at the corners of the roller fairlead you might have some issues with the rope getting stuck in there. Aluminum hawse fairleads are so cheap these days that there isn't much reason to use anything else. Sell your roller on ebay and get a hawse for 30 bones.
    j
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    but my only problem with the hawse fairlead is i`m having trouble figuring out how to mount it
  5. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Show a pic of the problem, I recommend a hawse also, thats what I have.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    as soon as i get back from Dunks!:D i think i may have come up with a solution
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i think i got it covered...now i just need to get someone to weld it on...:eek1: ...got put two plates (where the red is in the 2nd pic) and then drill the holes and bolt up
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    that will work right?
  9. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    yep
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    cool....just got home from a wet day at work so i`ll dry up a bit then head out to the shed to do some :hack: :grind:
