The latest complication: cracked shock mount repair
Discussion in 'The Garage' started by mplogic, Jul 1, 2002.
  1. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    I'm amazed at all the unrelated problems we've found during the axle swap and lift on my 89. I guess it's good we found all this and are taking care of it, I'm just waaaay over budget with all the little unexpected extras. /forums/images/icons/smile.gif
    Anyway, there are some hairline cracks in the frame around the shock mount on the one side. The other side, with the mount that is riveted to the top of the frame rail is also cracked all the way through on the top where it is the thinnest. Ultimately I want to get some extended shock mounts but, I don't want to go that route yet as then I'd need new shocks too (and who knows what else). Anyone know of a weld on repair kit for the factory locations or maybe an aftermarket bracket that supports the shocks on both sides? If I can't find anything else, I'll probably just get a couple steel plates welded up on the frame mounted side, but I'm in a quandary what to do on the other side (top of frame rail mount). There doesn't appear to be much room to work with there. Any suggestions?
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    I think the MO offroad relocation kit as well as Jeremy's kit (Howlin off road) both have multiple upper holes so that various lengths of shocks can be used.
    I relocated my rear shocks myself and re-used the 4" lift shocks I had anyways.
    After repairing busted shock mounts (upper and lower) for the third time I came to the conclusion it wasn't worth my time to do again. The factory design lends itself to self destruction...
    Rene
  3. mplogic
    May 7, 2002
    263
    Phoenix, AZ
    Thanks, I'll check those out.
