the lever from the tranny to the shifter on the colume restricts....
Discussion in 'The Garage' started by down4thakrown, Jul 3, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    :confused: the colum from goin all the way into park. :confused: it doesnt look to be able to adjust it
  2. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    oh yea its a 75 p/u cab on a 83 k5 frame 350/350/205
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I thought the adjustment was down beside the tranny??
  4. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Column Shifter
    If no adjustment, it sounds like something may be bent. :thinking:
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    theres not much of an adjustment. i thought the little shaft with the fork looking thing the rod goes throught would be splined but it only goes on one way. its only off about a 1/8-1/4 inch. it might work though but wont know until its time to start it
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it is adjustable its a slider, loosen the bolt head down there on the rod then you can slide the rod
    the bolt end screws up against the rod tight and keeps the adjustment, its under the truck
