The never ending brake bleed, bad M/C?
Discussion in 'The Garage' started by Okiemuddog, Apr 14, 2003.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gifWell after continual tries of gravity bleeding, 2-man bleeding and knuckle bleeding /forums/images/graemlins/angryfire.gif. My brakes are still screwed up, My /forums/images/graemlins/k5.gif had sat with no brakelines on it,thanks to PO, before I bought it. I installed my new Procomp lines and let the bleeding begin, I have been through 2 big bottles of brake fluid, you can pump them about four times and they have great pressure, but when you let the pedal back to the top the next time you push it, to the floor it goes.
    SSSSSSSOOOOOOOOOOOOOOOOOO..............
    do I need to continue bleeding or does it sound like the master cylinder is shot?
  2. Storm Trooper
    Nov 24, 2000
    4,640
    I had my scout do the same thing. I thought I was doing something wrong some how but it did turn out to be the Master. After that was changed it worked fine.
    I'd change it out.
  3. Suburbanite
    Suburbanite Registered Member
    Dec 1, 2001
    74
    Florida
    Went thru the same routine with my nephew's '93 K1500 Z71 Sportside a couple of months ago. Replaced the MC & still no better. Turns out the rear drums/etc were completely shot! Old age in combination with my nephew's 'muddin' did them in. Once the rear was redone, braking was fine. So .. 1st check the rear braking system.
  4. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I had a never ending brake bleed on my truck once. I never lost pressure on the first push on the peddal though. I couldnt get one wheel cylinder to quit sperting out air as I blead it. It was sucking air in when I let off the peddal. New wheel cylinder and it was fixed. So, is all the air out of the system? Are your wheel cylinders leaking? Are your calipers leaking?
