The new engine is installed
Discussion in 'The Garage' started by white_knight, Jun 8, 2005.
  1. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    She lives once again !!!!
    433 BBC FIRST START
    Some tweaking and dyno yet to come...........
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    well thats just begging for RPMs
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Don't you just love the smell of a new engine when you start it for the first time. I love the smell of engine paint and RTV silicone burning in for the first time. :grin:
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    what kind of fuel are you running in that? I was about to say "and the smell of race fuel" but if you have EFI(read have an O2 sensor) what fuel are you running? AFAIK leaded fuel destroys O2 sensors.
  5. white_knight
    Feb 23, 2001
    1,171
    We will be running race fuel
  6. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    That thing is a BEAST!! What are the spec on it?
    BTW, I don't recall ever seeing a write-up in any off-road mag about your rig. WHY NOT?
  7. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Looks and sounds good Theresa!! Is one of the injectors messed up though? The close up shot of the throttle body showed a pretty drippy, gloppy spray pattern on one injector. :dunno:
    Rene
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I thought something looked off too.
    To check a TBI injector, slap a timing light on #1 and point it at the TB, adjust the timing(need an adjustable light, but I bet you have one) and adjust it till the spray pattern looks solid(like there is no pulse, due to the strobe of the timing light). If you can't get that out of it, somethings likely not right, or if the cone looks messed up, again.
  9. white_knight
    Feb 23, 2001
    1,171
    Specs-
    It;s a 433 BBC.
    11.3:1 cr
    Childs and Albert hd alum. rods w/ floating pins
    Keith Black diamond-cut pistons smoothed tops for hot spot alleviation
    Msd pro-billet distributor
    2.19/1.88 ss valves
    Lunati .692/.693 solid roller cam and springs
    Crane roller rockers & lifters(mechanical)
    Bbc steel crank
    Fully balanced-race
    radius valve job
    Ported and polished heads-within 1/2 cc
    Cat sfi dampner
    Cat stud girdle
    7/16 hd race pushrods and retainers
    Meziere electric water pump
    Cam button
    Bronze cam gears for billet distributor
    All ARP ss fasteners
    ARP rod bolts
    8+ qt oil pan and moroso pick-up and high volume pump
    7500+ rpm reliable consistently
    roughly 580 hp/575 ft/lbs with single plane manifold
    We changed a few things .
    New roller cam- intake lift .653 , .660 exhaust
    Intake duration 286
    exhaust 292
    and valve springs to go with the cam
    We took off the aluminum rockers and replaced them with cromoly rockers
    Intake has also been changed.
    Why not a write up????? Ask them.....I don't know.
    There have bee small clips here and there though
    We were on discovery channel this spring though
  10. white_knight
    Feb 23, 2001
    1,171
    There is teaking to be done. We do have spare injectors if need be.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Cool, thats a trick I was just taught today so, you know, new knowledge I simply have to share. An old GM tech I have for a teacher taught me that.
  12. white_knight
    Feb 23, 2001
    1,171
    Thanks.
    Appreciate that. :)
  13. white_knight
    Feb 23, 2001
    1,171
  14. wy4tt
    wy4tt 1/2 ton status
    Feb 20, 2005
    153
    USA
    That is a beast, and a beautiful engine. Great work! Is the Lunati one of the new Voodoos?
  15. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    its no k5 anymore but i like it. :D
  16. white_knight
    Feb 23, 2001
    1,171
    You are correct. Leaded fuel and O2 sensors do not mix as we just found out eventhough some told us it would last for a while.
    We've already burnt 15 gallons of fuel on testing and it hasn't left the garage yet.
    Another thing, K&N Billet aluminum micro filter fuel filters do not work . They restrict fuel flow.
    We'll be running VP Motorsport 109 unleaded
    More to come
  17. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Not knocking it, just curious - why aluminum rods?
    As always, very cool truck and great video! :thumb:
  18. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    That truggy is sick!! I love it...
  19. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    lord have mercy...there goes the neighborhood
    that mutha sounds good dude....!
  20. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    Man that thing roars! :bow: Looks awesome dude. You gotta post some footage of the first drive, and the first trail ride!
