The NEW TIPS AN TRICKS THREAD
Discussion in 'The Garage' started by Jeremy_C, Jul 18, 2005.
  1. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    I know we have posted these before, but i couldn't find it......mainly cause i didn't wanna search for 3 hours... :D
    Post up your little tips an tricks ya do.......If its overly complicated, explain it good so us simple folk can understand it.
    1. When soldering two wires together, crab a spray can lid, turn it up side down an slice two places in it opposite from each other.......now you can slide your wires in there an solder them.
    2. If you like to keep the inside of your rig clean an smellin good, a Bar of soap under the driver an passenger seat is an good cheap air freshner.
    Thats all I can think of right now........i know some of ya'll will have some good'ens :-)
    LETS HEAR'EM!!
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    A length of PVC pipe that fits inside your raditor hose and 2 hose clamps is good to keep in your truck in case your hose burst's
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I keep a bar of soap in my tool box for small gas tank leaks. I had a crack in my tank that was patched. If the tank was full and sat for a while the patch would start to leak again. Just chisel the epoxy off and rub the bar of soap in the crack and it will stop the leak long enough to get you home and or to apply more epoxy. I have done this several times andd it does work!
    Also you can use your hi lift handle on the end of a ratchet to get some extra leverage on those rusted on nuts and bolts.....use lots of PB blaster and or WD-40 :D
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    WD-40 makes a pretty good hand cleaner. Just spray it on your hands and wipe it off. To re-seat the bead on a tire, use a ratcheting tie down strap. Wrap around the tire, start tightening it up as you air it up.
  5. puckhead
    puckhead 1/2 ton status
    Jun 17, 2005
    112
    colorado
    use a hose attached to intake manifold vacuum to unseat beads on your tires (engine must bee running)
    a 1/2" 12pt box wrench works good for popping park brake cable casings out of the brackets (the ones with the 3 little tangs that pop out when installed)
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    a high lift jack handle can be used to sleve a broken tie rod
  7. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i heard somthing about using lighter fluid to pop a tire on the bead. never done it though, couple of pry bars and pushing down on the tire while putting air in it always worked for me.
    If your ignition switch fails on you when your on the trail, pop the hood and where the wiring harness is there should be a purple wire. If you splice a hot wire to it and have the ignition on, your truck should fire.
    If your solenoid fails on the trail you could ethier grab a hammer and give it some good wacks or get a long screw driver, long pry bar or similar and arc the the 3 points on the solenoid it will turn the truck over. but you have to touch all three. if you dont, usually the starter will spin but not engage. make sure theres not alot of fluid around starter because there will be alot of sparks and becareful not to touch the tranny line cuz it will cause a hole.
    if you get a small hole in the radiator fins. melt solder so it drips and drip some on the leak.
    dont go playin in the mud as soon as you get to the pit, let your truck cool down a bit to avoid seizing or warping.
    you can make a funnel out of a bud light box
    beer cans and chicken wire will help seal a new exhaust leak but its only temperory. use more then one can and it will last longer.
    red glow sticks usually help to keep the cops off your back if you have lost your tail lights and have to drive home that night
  8. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    if you have trouble finding a vacuum leak, spray some carb cleaner around where the leak could be occurring (while the engine is on) and listen for the engine to choke on the rich mixture... kinda has to be a decent leak though
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Hate those messy oil changes with oil running down your arm and all over the ground?
    Sharpen the end of a large nail and hammer it through the bottom of your oil filter. Loosen the filter a turn or two and let all the oil drain out the filter while you empty the oil in the pan.
  10. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    i learned this from a guy i know...
    out camping and wheeling...
    get a hole in your radiator from some branches or something..?
    go back to your camp site, grab an egg or two..open the radiator cap, crack the egg, pour into radiator, and let the engine run..
    the eggs will boil and fill the hole..
    the guy i know, did this to get his heep back home..
  11. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    when drilling out an existing hole use a multiflute or miltitooth countersink as it will self center and not walk on you and make you loose your posistion, and it ramps out the back side of the metal and wont grab and twist your power drill like a drill bit will. step drills work too but the step depth is not deep enough if your part is thicker then the step depth. it will save you a possible broken drill bit or at worst a broken wrist. i have our grind shop grind me custom sizes so when i remount say a bracket that was factory riveted and i drill out the 7/16 rivet hole to 1/2, the stock 1/2 c'sink that measures .510 i had ground to .496/.497 will give a close fit over the bolt to allow no possible movment of a bracket, allmost like a rivet. this only needs to be done where nonmovement is important. im a machinist so i dont like sloppy holes in my women or for my bolts either. :D
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    It will actually increase the RPM on the engine a little bit
  13. fire dawg
    fire dawg Registered Member
    Jan 24, 2005
    28
    new mexico
    i saw that egg trick on an episode of mcgyver once. he used it to plug bullet holes :D
  14. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    no i think he is right, it will kinda choke on it
  15. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    allright someone go pull a vacume line and spray the stuff at it to see what happens so we dont get a piss'in match started here. :D
  16. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I've actually done this. Its fun, but not a great idea. We used a long lighter and the tire snapped the end off when it reseated. :eek1:
  17. cbbr
    Jul 17, 2004
    14,681
    Start a poll. :D
  18. BIG*RED
    Mar 14, 2003
    1,094
    well one time i had the engine running and was spraying carb cleaner around the base of the carb, and when i got around to the back, the engine bogged down..thats how i found that the two rear bolts on the carb were a little lose..
    so my vote, is that it will bog down :D
  19. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    No, the RPM will go up. Something like water will cause it to stumble. Even windshield washer fluid will cause the RPM to go up.
  20. koke01
    koke01 Registered Member
    Jun 15, 2005
    6
    IL
    we reseat car tire beads by spraying starting fluid in the tire, and throwing a match in, but poped on so fast that the wheel balancing weights hit the ceiling, pretty hard. I wouldn't recomend doing it
