The original Guardsman from DIY4X
Discussion in 'Vendor Forum' started by cybrfire, Sep 19, 2005.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Here's the real deal, the original Guardsman. A full half inch thick. Read the tech review by one of our own CK5 members here>
    TECH REVIEW
    This is one piece you don't want to sacrifice on strength.
    As always $65 and if you use the "Buy it Now" button on the website its actually only $60. That includes all the hardware required. Of course Grade 8 bolts and they are pre loctited.
    There's quite of few of these out there, you guys that have them, let's hear some feedback!
    I'll be posting up some pictures of the newest revision. Not much different just a little bit more beef and clears 1410 ujoints thanks to Jesse at High Angle Driveline.
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Yep, I've had one for over a year. As always top notch products from Kert. :waytogo:
  3. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    While writing the review for Kert, I tried to get the Guardsman to hang up...it really is more of a rock slider than most people believe!
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That's exactly what customers are reporting. Thanks again for the tech review! You did an excellent job with it!
  5. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I have one on mine and love it. Thanks for the great products,
  6. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Also, if you notice, Kert's design of the original Guardsman has better ground clearance and less reason to drag on obstacles than other "imitation" and poorly designed "knock-off" pinion guards.
    If you have a 14BFF, buy the original guys-
    The Guardsman
    Found only at DIY4X!
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I noticed the design of one of these "imitation" pieces resembles a plow... How can mounting a plow under your truck be any good? The Guardsman appears to be a well though out design built with THICK material.
    I would buy one if I had a use for it, but I don't. I am, however, very pleased with my disk brake brackets. They are very well made parts and the kit includes solid spacers instead of pipes.
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Thanks for all the props guys. The best advertising their is!
  9. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    would it be possible to get one made where the top part extends beyond the bolts a bit? I want to integrate it into a truss system. It'd be less work for you, I just want it flat across the top... maybe an inch taller than the standard model. :)
    j
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Absolutely. Cost difference would be extremely minimal!
    PM coming your way.
  11. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Just bought one the other day :D
  12. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    I bought one so I could use it at Blazer Bash this year. Well with three million other things to do to get my truck ready for the drive out there, the guardsmen was kind of low on the list. So at 1am the night before I was to leave for Moab I ripped this thing out of the box. I had it completely installed by 1:30am :D
    I got to use it at Blazer Bash too. I heard other people calling it a "shovel" but that has not been my experience with it. Maybe if you were doing strictly mud it wouldn't be a great idea, but when you routinely drag you diff over rocks, I consider it a neccesity. I scraped it up a bit, and didn't even bother to look at it until the end of the weekend to see how much paint was left.
    I love it! :thumb:
  13. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    Just got done putting my order in today :D
    :waytogo:
  14. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I need some stuff. Guardsman for 1350 in a 14ff, 14ff spring plates, D60 front spring plate, u bolts for both and spring perches for the 14ff. Ya got all that??? And shipping to 75002
  15. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    One more request - can you make one that also extends back to help hide the 14ff lip/anchor? I will be gring a bit on mine but it will still have a bit of a lip that would hang up on things. A skid would help here. Do you think the pinion mount would be strong enough? I suppose if it was a tight fit on the pumpkin and could not be used as a lever it would be fine....
  16. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    It'd get hooked on stuff going backwards unless it were tied into the cover. Gotta back up sooner or later. Not impossible but I don't think you'd want it just hangin there.
  17. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I have one on the Willy's. for the price it's a cheap piece of insurnace to know the rear joint is protected, and at the size it's pure beef.
  18. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Just ordered one from you. :waytogo:
  19. mtn. burb
    May 13, 2004
    1,260
    Ojai Calif.
    Update - I have my Guardsman, this is a serious piece of work.
    Heavy duty and nice welds.
    Thankyou!!:D
  20. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Has this revision for the 1410 joints been put on the market yet?
