The Payloader that wouldnt die
Discussion in 'The Garage' started by Drey, Aug 18, 2006.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    OK Im on my lunch break so Ill have to make this quick. At work bout 20 min ago. The old junk Hough Payloader died. Rod and Gary got it to start again and brought it down to the shop and parked it. Rod turned off the key, but it kept running:crazy: , so then he pulled on the choke...still running:( . I then went over and yanked on the Plug wire coming off the coil...sucker still ran.:confused: Then is started to blow white smoke for a bit...then REALLY black smoke. Still running so I took my cap off and covered up the exhaust pipe it finally quit.:eek1:
    Good thing its going down to a big equipment auction:haha:
  2. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    Diesel???
    If it was a diesel,it sounds like a "runaway!"...thats when they run on their own oil fumes from blowby in the crankcase!..it can make them rev up way beyond the govenor settings and toss rods out of the block!..:eek1: ..seen a bulldozer do it once--it was COOL!..:haha:
    I once drove a 72 Nova 20 miles home from a bar, kinda blitzed, when I was a lot younger--its owner,my best friend,was too buzzed to drive,and halfway back to his house I noticed the temp gauge was PEGGED!..it started to "spark knock",and I figured it would seize unless we stopped!--my friend said "dont stop,if we do the cops will probably pull up behind us!--KEEP GOING!..:eek1:
    As I drove closer to his house,the motor got louder,like the lifters were collapsing--then it started skipping at red lights,and each time it fired you could hear a spark knock or slappy piston noise!--how that thing made it all that way is beyond me!--when I shut the key off in his driveway,the engine didn't stop!--it actually smoothed out and ran BETTER!! --I had to open the hood and close the choke to "smother" it!--burnt the hell outta my hands in the process--the exhaust manifold was glowing ORANGE!..:eek1:
    The next day,we found the lower hose nipple had fell out of the radiator!--I got another radiator from the junkyard and we installed it--much to our suprise the engine started right up,sounded OK again!..changed the oil,and drove it another couple of years..didn't even blow the head gasket!..:screwy: ..try THAT in a Honda,or other "aluminum" motor!..:rolleyes: :crazy:
  3. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    that's awesome! I would never sell that! if you can yank parts off and it won't quit?? that's one tough hough!:laugh:
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Its a gas, I dont know what the hell the deal was...and no If you ever ran th is thing you wouldnt want to keep it...MAJOR pos. Entire brake system is shot. Onlyway to stop is to lower the bucket. No power steering. Its rear steering too.
  5. jonny290
    jonny290 Registered Member
    Aug 1, 2006
    19
    fayetteville, ar
    It's called 'dieseling' for obv reasons. Your head/cylinder is getting hot enough to ignite the air/fuel mix on the power stroke. Happened a bit in my '77 Nova with the straight 6 and a dime-sized hole in the radiator. Filled up every 2 miles, and it'd diesel for 5-10 seconds.
    I did this EVERY DAY to that poor straight 6 for two months, and it still ran perfectly. God Bless American Steel, hahaha.
    (I've since learned to fix radiators, lol.)
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Friend of mine used to work in the oil patch. Was once on a job where they had a big diesel stationary that got more than just a wiff of leaking NG. There's a reason those have 1/4" thick doors on their intakes. While everyone else was scattering for the hills the foreman knocked the prop rods holding the doors open out. Ruben said it sounds like that thing hit 30,000 RPM :doah:
  7. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    This last winter @ work we were pullin' a houseboat out of the water and the clutch on our mack wouldn't engage or disengage, leaving it stuck in gear or trapt in neutral. So we had to use the starter to pull the truck, trailer, and houseboat forward in order to get it in and out of gear. well.... it rolled forward a few feet one time, didn't fire up, boss didn't throw it out of gear in time, and there was enough force and load to fire the truck up backwards!!! Im talking about the exhaust stacks were sucking in air, and black smoke pouring out the intake stack. We all sat and looked at eachother for a while, and finally i yelled out "It's F(@*#$& RUNNING BACKWARDS!!!" It was bizzare, and the first time i've ever heard of anything like this happening. After laughing and staring at it for a while, we shut it off. Then it fired up normally right afterwards, minus a little bit of extra black smoke for a minute.
  8. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    wow!!! i wish i had a crazy story to tell!!LOL
  9. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    any 2 stroke Detroit can easily run backwards, all it takes is a good solid backfire. I was with a Caterpillar C7 acert engine that ran away in a highway coach while backing into the shop. Generally the turbo oil feed line gives the oil to runaway on, shot oil seals in the turbo allow ungoverned oil fuel to the engine. This twin turbo C7, upon downloading the ecm, hit right around 6,000rpm before it drained the oil pan and shut down.
  10. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,612
    561
    Wasilla AK,
    I've seen a 3500 series Allis Chalmers runawy from bad turbo seals I managed to stuff some rags in the intake before it went boom .... but it wound out real tight before I did.....directly after I had to change my shorts:eek1:
  11. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    once when my dad was younger he filled up one of the diesel flatbed trucks at work with regular unleaded and it did the same thing. he said they did everything they could think of and it ended up running until it ran out of gas.
  12. eclmech
    eclmech Registered Member
    Apr 9, 2006
    24
    Ontario, Canada
    CO2 fire extinguisher shuts runaways down quick and safe. No damage if you catch it quick.
    Keith
  13. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    or an repair manual!..
    Where my older brother works ,he maintains a diesel fleet of Macks..they had one old truck start to "runaway" in the shop once--my brother knew smothering the intake is the best way to snuff it out,and he used a "Motor's" repair manual book to cover the intake pipe!...he was the only one brave enough to grab the book,and climb up on the truck to use it to kill the motor!--everyone else was running away as fast as their legs could carry them!..:p:
  14. savagek5diesel
    Nov 20, 2003
    310
    Redding California
    When ours fired up backwards, it was different because we had throttle control, it didn't rev. like the rest of the stories here........hmm, now my brain is thinking again....
