The Quest for telfon leaf spring pads
Discussion in 'The Garage' started by ColAdo82K5, Nov 13, 2004.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    hey ya'll,
    Who can find some teflon in 2.5 width strips for our style of 52inch rear springs ? I want to build a pack that uses a 8 inch rectangle of telfon between each leaf using the centering pin to hold them in place. I've heard of several people doing this with good results. Online source ?
    Blake
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    8"?
    the slippery bit needs to be at the tip of the spring
  3. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
  4. ColAdo82K5
    Feb 18, 2000
    789
    MO
    The springs I have don't have holes for the telfon tips. I've seen a few custom shops that did it this way as well. Such as Deaver or Eaton...
    Know of an online source for the teflon stuff or how to drill to add the telfon tips?
  5. ColAdo82K5
    Feb 18, 2000
    789
    MO
    Thanks !
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I just drilled mine for the buttons
    wasnt hard at all
    I did break a 7/16 punch on the ironworker trying to punch them
    but the drill press made short work of it
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    St. Louis Spring can hook you up with some teflon pads for the tips if you do it that way, 75 cents each.
