the reson I used a 6 foot pry bar to smack a nice dent in my fender
Discussion in 'The Garage' started by sled_dog, May 1, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    cause installing an SM465 all by yourself with only a 5 ton jack that has a pad circle of about 3" is VERY VERY hard if not utterly impossible.
  2. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    You should rent a floor jack with a transmission head bracket to put the transmission in. They only cost about $15 to $20 a day to rent, and you usually will only need for one day. Taking the transmission out can be done with a little floor jack, but putting them back in is a whole different story. The SM 465 weighs about 400 pounds. Using a small floor jack to line up the splines and pilot bearing with the transmission input shaft, on a 400-pound SM 465, is like trying to park a Greyhound bus in a front row spot at the Mall on a Sunday afternoon.
  3. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I agree. I used a floor tranny jack last time I pulled that heavy SOB out of my 72. I even did it with the transfer case attached.
  4. nvrenuf
    Jan 7, 2002
    13,082
    250
    Mobile, Al.
    I had a friend do it once using a motor hoist in the cab with chain dropped down through the tunnel holding the tranny. /forums/images/graemlins/thinking.gif
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I used a cherry picker to install my Th350 and doubler as a single unit.
    And as for the dent... Nah, I don't believe that... You just wanted to look more "hard core"... /forums/images/graemlins/cool.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    nah I just wanted to care less. Not often trees leave single little dents in a couple inches. I tried the hoist thing, destroyed the dash(I didn't care it is coming out). Thing is I had to pull through the shifter hole cause thats all I have, this is an Auto to Stick swap so the tunnel doesn't just unbolt. I borrowed a tranny jack setup from a friend so as soon as dad gets the jack that I need to use home I will get to work on it.
  7. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    Did it the cherry picker through the cab way yesterday. Worked quite well. First time I used my new cherry picker and I love it already.
    John
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    th350/203 at the adapter is almost balanced. We where covered in oil so I dont have during pics, but this is after it was pulled up and bolted in
    pull the passengers seat and stick the engine hoist in. Hook it up, drop it down. pull it out slide the new one under and pulled it up into place /forums/images/graemlins/waytogo.gif
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Interesting. My 79 with the TH350 has a removable tunnel. I fabricated a large tray for my floor jack. Take out the small round pad and slide in the tray. I have removed and installed countless auto and manual trannies with and without the transfer case using it. Low tech but does the job.
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I could remove the tunnel but there are no bolts, its pinched or spot welded together.
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    2wd cab ??
    hmm..
  12. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my dads 85 blazer with a 465 does not have bolts for the tranny tunnel, so i didn't remove it.
    when we put the cluch in all we had was a "big" 2.5 ton and a "small" 1.5 ton jack. the only way we could figure out how to do it was roll the blazer back and jack both jacks up a little bit till it was in and could put the bolts it. /forums/images/graemlins/waytogo.gif
  13. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    400lbs? I know mine doesn't weigh anywhere near that much...
  14. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I was scratching my head one day on putting one of my TC cases back on and I completely forgot I had a motorcycle lift. Cut a piece of thick plywood out to make a platform on top of the two padded bars and I was cookin' with gas. Put the TC case on the big square flat plywood platform, adjusted the angle and tilt with smaller pieces of wood, and slid the thing right in. Did the same for the tranny earlier.
  15. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    Yea, I think they weigh more like 200 pounds. Did you here about the fish I caught that got away? /forums/images/graemlins/whistling.gif
  16. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    It looks dangerous, it ripped your pant leg!! It's on the passenger floorboard!!! /forums/images/graemlins/yikes.gif
  17. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    ohhhh (Tim The Toolman Taylor noise)
    Motorcycle lift... creative use of tools. Also be good for horking winches, bumpers, anything heavy... and there's this guy in Emeryville who has cheap ones... hmm...
    -- A
  18. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    The way I installed my trannt was with a floor jack but we couldn't get the damn t-case to balance on the jack at all so three guys lifting got the job done.
  19. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    The 465/205 Combo weighs 400 when bolted together. And I feel his pain, I had to put the combo in by myself.
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    -- A
    [/ QUOTE ] Friend told me to do that, but I don't have a motorcycle jack, just a snowmobile jack, which is too big for under the blazer. Dad figured out a good setup for it, I will take pictures. I could have done it as well, but I'm too damn weak to lift I'm under the blazer onto the jack and all.
