The right GEARS!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlkBlazer86, Jul 11, 2001.
  1. BlkBlazer86
    BlkBlazer86 Registered Member
    May 16, 2000
    15
    Plainfield, IL
    The guy I bought my 86 K5 from was going to lift the truck so he put 4.11's in. My question is I want to run 35 inch tires and I want to know is this a good combination????
    Chevy Powered!!!
    BlkBlazer86
  2. MY85GMC
    MY85GMC Registered Member
    Jul 1, 2001
    11
    sounds good to me as long as you are running like a 700r4, a TH350 might even work well but with the 700r4 you could even get away with 4.56's
  3. BlkBlazer86
    May 16, 2000
    15
    Plainfield, IL
    Yeah I am running a 700R4 so it should work fine right. One thing my speedo bounces and it appears to be about 5 or 10 mph off and is it my gears causing that?????
    Chevy Powered!!!
    BlkBlazer86
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Lower gears will cause your speedo to be off if you are still running stock tires.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</A>
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    4.10 gears will work okay with 35" tires, though in my opinion something lower (like 4.56 or even 4.88) would be ideal since you have any overdrive trans......though I would not suggest going to the expense of changing out the 4.10's at this point.
    No, the gears (assuming you are talking about the 4.10 gear set) should not cause the bouncing of the speedo, thought the combination of the gears and larger tires will cause it be off in regards to speed.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    4.10s work well with a 700R4 with 35s. I know, as I have them. If I didn't have a built motor though, I'd want 4.56s. Actually, I want 4.56s anyway. It always helps to have a little more gear than you already have. Seems you're never happy with it.
    Tim
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    The bouncing speedo is probably a messed up speedo cable... it is either damaged or is bent. You'd probably be well served to put in a new one. 4.10's and 35's is what my truck has w/ a 700r4... works nice... 4.56's would be nice too... but would hurt more on the freeway
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
