The right locker for me?
Discussion in 'The Garage' started by Scrubby, Mar 21, 2005.
  1. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    I have a 72 blazer, 1/2 ton axles, and 33s. I'm a once in a while wheeler, and I don't go very hard core. I'm looking for a locker for my 12 bolt.
    I'm curious if it is worth going with the detroit in the 12 bolt. Would I be ok with something like a lock right since the 12 bolt isn't that strong anyway? Or is it just worth the money to get a detroit?
    I'm going to stick with the 1/2 ton gear for a while. I know the best way to go is to get a 14 bolt and drop the detroit in there, but I don't want to go there yet.
  2. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    i wouldnt put any locker in a 12 bolt...especially considering the way you use it. Lockers are really only needed for hardcore stuff. They don't help the resale value of half ton stuff really, so its not a very good investment either.
    j
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    For what you would pay (or less) for a locker for a 12 bolt , you can find a 14B already with a locker. just find one with the same gears may be the only obstacle. It's just a bolt in swap..normally
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Lockright , inexpensive , you CAN install yourself :k5: :k5:
  5. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Put a lockright in it. $200, and an hour of your time and you are done. Cary a spare shaft just in case, but unless you wheel with your glued to the floor, you shouldnt need it.
    If you go 14b, you need to swap to 8 lug rims, and with only 33's you can kiss ground clearance goodbye. A locked 12 bolt should hold up just fine with only 33's as long as you dont get crazy with the stupid pedal.
  6. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Lockrite
