The same spark plug fouls every week...help?
Discussion in 'The Garage' started by platapus, Sep 30, 2006.
  1. platapus
    platapus Registered Member
    Jan 15, 2006
    37
    CALIFORNIA
    I have a SB 350 in my K5, it has developed an annoying problem, about once a week the same sparkplug fouls due to carbon build up (it fills in the gap on the electrode, causing no spark). The rest of the plugs a very clean, any ideas as to what is causing this? Should I swith to a hotter plug?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Does that plug-fouling cylinder vary from the other 7 on a compression test or a leakdown test?
  3. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I'd also be suspicious of a leaky valve guide on that cylinder. nothing fouls a plug up like lots of oil..
  4. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    something is telling me it's a cracked ring or something..... b/c my buddys Monte Carlo did that same thing every week til he tore the motor down to find a cracked ring in the cyl. that was fouling the plugs.
    LUKE
  5. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i had that same problem, i dealt with it because i couldnt actually deal with it the right way so i just cleaned em and put em back in. if i drove more than 30 minutes straight it would foul out with oil but if not i could go forever if i just took short drives. so really i have no idea what it was because i sold it.
    sorry for the worthless reply
  6. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i have the same problem on my vette. it has one bad cylinder that fouls out every 100 miles. its becouse of oil, most likly the valve seal or guide. iput on what they call a " no foul " . its a little thing you screw on the plug then install in the head. it keeps the oil from getting on the electrode but you still have spark. if your engine is not too bad it will work. you can buy one at a auto parts store not expensive.
  7. platapus
    Jan 15, 2006
    37
    CALIFORNIA
    Thanks scrappy - That sounds like a good temp solution. Im going to drop a crate motor in. But this buys me some time until Im ready to do that.
