The Sawzall is addictive... when do sliders become boatsiding?
Discussion in 'The Garage' started by dremu, Aug 25, 2005.
  1. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    Dangit, I enjoy cutting :hack: too much. I was just gonna weld in some square tube (well, rectangular) to replace my sills and maybe notch the rocker boxes. But they were rusty and not doing much and the tube didn't fit well with them ... so I cut them out. (Well, one side ... gotta do the other yet.)
    Anyway, put a nice 2x6 .250 wall tube along there, integral slider like. Won't have to trim my doors (they're half doors, so it's not like it matters, but I'm lazy) and the tube is stout enough that it should take rock hits no problem.
    I'm still debating reinforcing the 2x6 to the frame ... or is that A Bad Thing and I should leave it only attached to the body? It just looks like some lateral strengthening is called for.
    Opines?
    -- A
  2. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Looks like you added a little something something to my roll cage......
  3. dremu
    Feb 27, 2000
    15,963
    454
    I *tole* you it got customized =))
    Here's an over-all pic of the cage ... you can't hardly see it, but the spare is up there ... and here's another installed pic, with some idiot trying to be gramma Clampett...
    -- A
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    why did you have to go and show me those pics... i've been thinking the rockers on my 73 hung too low, but i would want them reinforced, but how? maybe tied into the cage somehow?
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Need to put grannie up there in that chair :doah:
    ALTHOOOOOOUGH, that would be an interesting perspective while out wheeling,,, :thinking:
  6. dremu
    Feb 27, 2000
    15,963
    454
    Yeah, my buddy who took the pic -- and made me throw a spare bucket seat up there -- was saying it might make a hell of a spotter position.
    Note the seat isn't bolted down or nothing, so it's held in place in that pic primarily by the suction of my butt puckered down to the spare!
    At least the spare is solidly mounted to the cage.
    -- A
  7. dremu
    Feb 27, 2000
    15,963
    454
    Well, with the rocker boxes cut out, one could easily do slider-to-frame ... I'm thinking that some 2x2 square tube would work nicely... weld to the slider, and put some angle iron or something on the inside to bolt to the frame.
    Might be overkill though. ::Shrug:: Those rocker boxes take up a lot of space and just collect dirt and rust, from what I saw.
    -- A
  8. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    who done it?
    Who did your cage? Looks really good, and it looks like the cab is still really functional.
  9. dremu
    Feb 27, 2000
    15,963
    454
    It started life as a Simttybilt cage, I believe, that I got from Desert Rat (thus his commentary above :) )
    I cut off the rear runners from the Smittybilt and ran new tubes to an aftermarket rear roll bar. The lower cab sections were bent by a local guy and I added a coupla lateral sections as well (the unpainted sections vs. painted in the third pic.)
    The cab is still nicely open, yes, and the cage makes it easier, actually, to weasel in and out of the half doors. (Yes, I know the second pic has the full doors.)
    I am still contemplating running a bar across the dashboard at some point, but with the front legs the way they are, it would be REALLY close to the tranny shifter unless I have it custom bent. I figure if/when I put in lateral bits for the seats to mount to, I may do it all then.
    Oh, and thanks!
    -- A
  10. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Going to the frame not overkill.....
    Go high and nix the doors...
    Matt (az-k5) just did it the right way!
    Marv
  11. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i like that pic, is there more or a write up from him?
  12. dremu
    Feb 27, 2000
    15,963
    454
    bbbbbut uncle Marv, I *like* my doors :haha:
    I note that he used bushings to the frame, though. I think that's partially why I'm leery of just bolting to the frame, as it'll be a direct mechanical coupling from frame to slider to body.
    -- A
  13. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    :screwy: bah!.... :D
    Bushings is a good way to go. Rob's (therobzilla) is hard to the frame. still works! :thumb:
    Marv
  14. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I didn't want to make it too rigid, since the rest of the cage (well now more of a full truggy with all of the tube it has now) is tied into bushings since it happened in phases and the body supported the main cage until the boatsiding. The only thing I don't like about the bushings is that the bending moment about the tube is cut in half since it makes a hinged connection. I want to try and fit two bushings for each landing and triangulate the area. I probably won't get around to it and will build a full on buggy if it is a big enough problem.
    I am still trying to get doors back on. I have to rebuild a lower hinge, and cut the crap out of them (both for the boat side and the nose tie in). We'll see.
  15. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    OMG that is F#$king so kick ass :bow: u have gave me inspiration to follow your path, any more pics or specs on what u did? i really like this.
