the strongest way i can build my half ton axles
Discussion in 'OffRoad Design' started by BADRED73-N-AZ, Mar 10, 2002.
  1. BADRED73-N-AZ
    BADRED73-N-AZ Registered Member
    Jan 26, 2002
    65
    AZ, United States
    Im working with D44 FT 12 bolt rear looking to run 35 or 36 inch tires . I will be doing pretty hard core wheeling, but will also be seeing some long road trips. I was thinking of a full floater and detroit in rear with hubs in the rear does this meen i can run on the hiway with only one hub looked. in the front was thinking of a full spool and some of your HD axles. also debating 410 or 456 gearg. thanks for any info on these question.
  2. BADRED73-N-AZ
    Jan 26, 2002
    65
    AZ, United States
    by the way I for got to mention as far as gearing goes Im all ready runing doubler.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    the way i see it after buying a full floater kit and the shafts you can go get 3/4 ton running gear for the same price at a Yard.
    just my opinion.
    Grant
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    on the hubs issue , no bcuz u would go all crooked when u accelerated ....
  5. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    ff kit for the rear, chrome-moly axels f/r, premium hubs f/r, beefiest U-joints you can get, and some kind of truss f/r.
    Of course, as noted, for the price of all that stuff, you could go full 1-ton...
    J
  6. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    check out my pics page i have ord's olf beefed half ton axles .
  7. BADRED73-N-AZ
    Jan 26, 2002
    65
    AZ, United States
    thanks for responses ,and belive me if I could find A D60 I would go 1ton. but out here in AZ there next to emposible tofind and win you do they want as much as it will cost bild my falf tons. thin I still half to get a rear lookers wheels and tires. at least for now thats out fo my reach.
  8. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Ditch the 12 bolt. Much cheaper to build a 14, or even a 60 or 70 for that matter. And unless you go ultra high dollar, the 12 will still be a time bomb. Not so sure I'd want to go full spool in a 44 under a full size, either. If you are really planning to do hardcore rocks, I hope you like changing front shafts out.
    Pete
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    If you want to stay 6 lug, detroit the rear, add some aftermarket shafts and call it good. If you get into this very far you'll follow pete's advice and just start with a 14 bolt but that does require swapping to 8 lug in the front.
    I think we went over this on the phone some more.
