the vibration hunt
Discussion in 'The Garage' started by johnathan, Sep 26, 2005.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I'm getting a grinding vibration 50mph & up .I've had this vib. for a while I've changed the driveshaft,swapped rearend so I'm guessing it would be transfer case maybe,np208.Has anyone ever had this problem?
  2. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    whats the angle on your driveshaft and pinion? what type of shaft? what size joints? is your 208 slip yoke? need more info...
    j
  3. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    yeah 208 is slip yoke ,1310 in front of shaft 1350 in rear, no lift, don't know the angle of shaft ,I did'nt suspect that since it should still be stock
  4. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    one piece shaft
  5. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    how recently was the shaft balanced? new joints?
    j
  6. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    i swaped in a new shaft because the old one was just worn out. joints are new.I had the same exact vibe same speed with the old shaft.i never had the new one balanced ,it is used ,from newer blazer.there is a little play at the slip yoke.
  7. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    How long is the d shaft?My slip yoke was sticking out of the t case about 2 inches more than it should've been.It is being lengthened from 29 1/2"
    to 31 1/4".My pinion yoke was shot,bought a new one,my slip yoke was worn,bought a new one,and had my d shaft balanced with new spicer joints.It was still vibing,just not as bad.I'm hoping the lengthening works,I also had play in the slip yoke.
  8. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    did the lengthening work?
  9. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    It worked for me a little,most of my vibes were coming from the exploded gov lok in the rear end.Doesn't vibe now.
  10. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    mine is sticking out about 3.25" so i think im in the need of a lengthening
  11. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    after the shackle flip lift with new cv shaft no more vibes :D had to shim 4degrees
  12. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    Sweet,I need to redo the lift on my truck,blocks.I hope to get rid of the axle wrap afterwards.
