the vortec head swap
Discussion in 'The Garage' started by Cornfield creations, Oct 9, 2006.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I am figuring up prices for putting on different heads and everything included. I just need to make sure I'm not missing anything.
    vortec heads x2 12558060
    intake manifold for vortec head
    intake gaskets
    intake bolts
    valve cover's 12497978
    valve cover gaskets
    As far as a camshaft, I am unsure what to run. What is everyone else using?
    it's a 79 350 that is completely stock
  2. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Carb or tbi?
  3. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Carb, I wanted to use my quadrajet since it works
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    is anything wrong with your current cam? if not, try it. whatever pushrods you're using now should be about the right length. you'll also need the guided rockers used on 87+ engines too.
  5. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    yeah i think the cam seems good, never had a problem with the engine (if you don't call a lack of power a problem). I just thought the cam had to be changed with those heads.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    nope, an 87+ engine uses shorter pushrods, but also taller lifters. overall the lifter/pushrod combo is the same length. cams shouldnt really effect it, unless you're optimized for the other heads, but with a stock cam you should be fine.
  7. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I think swapping the stock cam out for something bigger with vortecs is a good idea, IMO.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    good idea, yes, NEEDED, no.
  9. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Be prepared for about a full point increase in the compression ratio. Your 79 probably has 76 cc heads and the vortec's are around 64-65 cc's. Would be great if you had an 8.0-8.5:1 motor. If it's already 9:1 you'd may run into some detonation issues.
    If you are running stock (unmodified vortec) heads, you'll have to limit valve lift to around .475-.480 inches of lift. My pic would be a cam with about 260 degrees of advertised duration and around .450-.460 inches of lift.
  10. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    There are a couple of places that sell Vortecs with modified spring seats that allow for lifts up to .525 or so. You can also purchase complete vortec kits with manifolds, etc. in one box. Is your current cam stock? If so, I'd bump it up a bit. Summit makes some cams with lifters for around $90. You're not going to want a very big one. If you've already got a RV cam I'd leave it alone.
  11. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Nope, it's the original cam.
  12. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Which intake is most widely used? I was looking at the edelbrock 2116, Or maybe an endurashine version!
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    looks like a decent choice for a mild engine. might want to rebuild the carb while you've got it off.
