Theft prevention idea
Discussion in 'The Garage' started by jakeslim, Mar 9, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Alarm, fuel cutoff, battery disconnect..all nice but do not keep an idiot from towing it away. I noticed that so many vehicles are stolen from "home sweet home". I had an idea to use a "bike chain". I bought some big ass chain from local hardware store and plan on chaining around d60
    and locking onto something in driveway. Best would be to install a lock point in driveway that is seated into cement. Now mine is not a dd so this makes great sense, but even with a daily driver, i am sure i would be possible to make it easy to use.
    What ya think? I already bought the chain and some big locks....so go easy on the idea /forums/images/graemlins/waytogo.gif
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I was gonna do the same thing with a trailer I have then the tire went flat so I don't think anybody is gonna try and steal it now. /forums/images/graemlins/histerical.gif Good luck to ya in the future.
    Allan
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    anything you can do to make it take longer is a good idea. I've heard of them cutting chains too though.... /forums/images/graemlins/ignore.gif
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    why not build a nice rebar rack into your driveway and weld one end of the chain to it..?
  5. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    It could work as a deterent to some but I would be a little worried still as bolt cutters are a thiefs best friend. /forums/images/graemlins/crazy.gif If they want it bad enough there is little you can do to stop em.
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    For it to work, you'd have to get a chain with REAL think links. As was stated above, bolt-cutters are a standard for every thieve. If it's not your daily driver then just take off one or two of the tires...
  7. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    yeah, the chain i got is very thick. I don't thing bolt cutters would work, even huge ones ont this. They could torch, but this is the tow-away type prevention so most likely you would "hear" the end result of trying to tow away something that is chained down /forums/images/graemlins/histerical.gif. Everyone on the block would hear this. All the other theft preventions do nothing to avoid the "tow away" scenario. /forums/images/graemlins/thinking.gif . It is by anymeans not a 100% proof idea, but it does through a headache into a thief's plan.
  8. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I bet that would work really good, of course you could just take off your steering wheel too. And hope they arent carrying a set of big vice-grips...ive seen a few farm pickups drivin around that way /forums/images/graemlins/histerical.gif
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Makita makes a cordless 4" grinder and a sawzall.
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what you need it a ancor chain from a cruise ship. one of my friends has one in his garage. it is huge, i link is about 1 foot long and 6 inches wide with the bar part beeing 1.5" think or solid steel. i think each link weights about 50 lbs /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  11. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    noisy, no worry's there. this takes time and makes noise...thats all the better for us! Get out that baseball bat(gun).
  12. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    if your going to chain it keep the chain as tight and as HIGH off the ground as you can... ever try cutting BIG chain with bolt cutters and not being able to put one in on the ground and pushing down? its HARD /forums/images/graemlins/waytogo.gif
  13. Confedneck
    Nov 1, 2002
    5,236
    transport chain..like chev4wd said, keep it taught so you cant get big bolt cutters against anything to cut the chain.. or.. you could just run the chain through your rear wheels and through the yoke at the diff. end of the driveshaft.. that would be a loud ass bang when they tried backing it up..
  14. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Put a big upside down capital L in the concrete made out of 2" square tube, then put the outward part into your reciever hicth with a huge pin
    Or not
    Actually
    Take the seat out, throw junk parts all over the place and have wires hanging out of the thing with the hood open and a bunch of wood all over
  15. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    detatchable steering wheel. Grant makes new ones that have a one of a kind key'd shaft that only matches the wheel you have.
  16. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    tow truck /forums/images/graemlins/doah.gif
  17. Confedneck
    Nov 1, 2002
    5,236
    a tow truck sure does make a lot of racket dragging a truck onto it when the front bumper is on the ground, just remove your front suspension when its parked..
  18. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    some guy just posted a theft(pirate board) of a sweet landcruiser in san jose. check it out..stolen from front of house of course. there is video of it also. not my cup of tea, but nice 4x4 classic just the same.
  19. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    you make it sound like having no seats, junk parts, wires and wood all over the place is a good thing /forums/images/graemlins/histerical.gif but it did give me an excuse to cut the roof off and narrow the front and rear of the rig /forums/images/graemlins/wink.gif /forums/images/graemlins/hack.gif (demolition blades are the answer to all your saw-zall needs!)
  20. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Now that I think of it, how would you guys keep someone fron stealing just your tires? I'd really like to keep my 39.5" boggers without having to dismount them every night. I was thinking chain but that could get old quick and is easy to cut if someone wanted to badly enough. Any suggestions?
