Thermostat Housing Bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by m4, Jul 20, 2005.
  1. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    wHEN IT RAINS IT POURS. HOW DIFFICULT IS IT TO DRILL OUT A BROKEN FLUSH THERMOSTAT HOUSING BOLT?
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    its not any more difficult than any other bolt...
    1)center punch it carefully... in the center obviously
    2)USE A NEW SHARP BIT...sized for the easyout extractor size ... 3/8" bolt uses a 5/16 IIRC
    3) Mark drill bit for depth...tape... magic marker ...whatever...so you dont drill past the bolt into the manifold housing... drill sober... no shakey hands on this one...leave the bud for the weekend
    4) use cutting fluid while drilling
    5) use easyout carefully... dont break it off in there or you will have a hassle getting it out
    6) clean it all up well and off you go
    cam
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    You missed step 0. :doah::wink1:
    0) Use a penetrating fluid like PB blaster and let it soak over night.
  4. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    opps.. youre right... the pb blaster step..... good stuff!!!
    cam
  5. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    It's soaking overnight, tomorrow I'll try.
  6. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I assume that maybe you are dealing with an aluminum manifold since I never had any problems with bolts in the old cast iron ones. After you get it out be sure to use anti-sieze. You could also put studs in the manifold and use brass nuts.That should solve the problem of getting it apart next time.
  7. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    if you booger the bolt hole too badly you can use a metric 10-1.50 heli-coil.
    my buddy bought a 91 c30 at an auction and both holes were boogered, so i bought a 10-1.50 heli-coil kit and redid both holes. make sure you get the kit with the drill bit and coil installer, not just the insert itself.
    worked great
    ryan
  8. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    Been gone for a while, a friend helped drill out the old bolt. Need to retap and go from there. Thanks All
  9. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    Okay, we drilled out the broken bolt, re-tapped and installed a heli-coil. I put the radiator (old) in fired it up and it was leaking at the heater outlet. Auto zone did the warrenty exchange and I re installed another radiator. Everything is good now. Thanks all
