Thermostat housing sensors
Discussion in 'The Garage' started by anjieandjohn, Jul 21, 2005.
  1. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    I just changed my thermostat out along with some of the vacuum lines. One of the two sensors on the housing broke off.....where can I find the part numbers for the two of them? They screw into the housing and the one that broke off has 4 vacuum line connections...
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i just got a universal one with the right threads on it and it worked just fine.mine is a 72 so yours may be different.mine only has one wire to send the signal.
  3. dyeager535
    26,975
    lmc IIRC has a pretty good selection of these. They are going to vary somewhat based on year. GM may even still sell them, they might be cheaper than LMC.
