Thermostat replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tuff84blaze, Mar 29, 2002.
  1. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    Now that it is getting warmer out I'm goingto replace my thermostat with a cooler temp. one, so that I don't have to drive around all summer with the heater on to keep the pig under 210 degrees. Anyways my question is weather or not I need to use gasket sealer on the new gasket when replaceing it.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    No..when I replace my thermostate, I just cleaned the surface real well and the new gasket has been sealing just fine without any RTV to help it out...
    Chris
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    it's cheap.. use alittle...
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    yeah, for the $3 a tube i think you can swing it
  5. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    You can do like I had to put it on with the gasket then have to go back and redo it with the gasket and the RTV..lol....It is is cheap preventive solution to a leak...mike
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I've never used RTV on the thermostat gasket and I've never had a problem. Maybe I've been lucky!!!/forums/images/icons/wink.gif
