Thermostat temp rating
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JTB, Jun 2, 2001.
  1. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    I have read that running a lower t-stat will increase power due to a cooler air/fuel mix, but running one that is too low will shorten engine life. What temp rating is the best? 160 degree, or is that too cool?
    Jeff
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    160-180 deg F.Depends on your enviroment.If you live in a warmer part of the country you might want to go with the 160.
    <font color=green>BobK<font color=green>
  3. Dan71gmc
    Dan71gmc Registered Member
    Mar 4, 2001
    51
    Most engines are more efficient at 180- 195 degrees, but I agree that it depends on your climate ,radiator condition, towing capability,etc. I run a 160 in my 63 Studebaker Avanti, a 180 in my 69 shortstep (but the heat in winter isn't so good), a 195 in the 2wd Blazer, and a 195 in the 4x4. Most will tell you it is a fine line between running a temperature that's efficient and overheating. You might want to experiment with a couple different thermostats and see. I like to see the needle on the left hand side, but cooler doesn't always mean better.
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I live in the Central Valley of California and 100 deg summer days is normal for us. I run 185 stat and also use Summit HighFlow waterpump and electric fan made by Flex-A-Lite the 2800cfm BlackMagic M150. My rig never goes above 200 in the summer and stays right at 185 in the winter. I feel this is perfict heat range for a 350.
    Good Luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If you live where it gets cold, a 195 is a good idea in a topless Blazer. With the 195, the heater works pretty good even with the top off. There is a big difference between having 180 degree water going through your heater core, and 195. The thermostat will not make a difference in overheating. If your cooling system can't remove the heat that the engine is making (HP = heat), a lower temp thermostat will not help.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  6. 2quicK5
    2quicK5 Registered Member
    Apr 18, 2001
    46
    TN
    General rules of thumb:
    195 F for passing emissions testing and gas mileage
    180 F good all around compromise for daily driving, light towing and moderate performance usage
    160 F for heavy performance usage (racing) and heavy towing.
    John
    1972 K5 Blazer: 400 ci, 4 sp, 4" springs, 35" Tires
    2000 Trans Am, A4
    11.97@114 mph
  7. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Blazer1970's last sentence is *very* important!
    FWIW, I am running a 160 degree Robertshaw thermostat in my Blazer, but I am thinking that I will get better fuel economy with a slightly hotter thermostat, so I am considering a 180. The difference in the amount of wear you will see from a 160 to a 180 is not extremely high, as it is the oil temperature that is more important in considering most wear factors. Keeping the oil temperature between 185 and 220 degrees F is important.
