Thermostat ?
Discussion in '1982-Present GM Diesel' started by BurbLover, Dec 22, 2004.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Last night while plowing with my K5, I couldn't get heat. Engine never got over 150. Thinking the thermostat stuck open, I replaced it with a 190 one. Now, It wants to run around 200-215. Is this okay or should I go to the 170 thermostat? Thanks.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you're plowing and you are in the 200-215 and not going beyond 230 at the worst, you are fine.
    The engine is most efficent around the 200-210.
    So if it can stay in that range you're good.
    Just keep watching it.
  3. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    Thanks. I've been watching that guage almost as much as the road:D
  4. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    Verify that your gauge is correct with an external thermometer. Either the gauge or the sending unit might be reading high. I just installed a new 195* t-stat in mine yesterday for the same reason-my gauge reads between 195-200 now as it should.
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    It's not uncommon, from what I've researched, for the factory gage to be inaccurate. Mine's off by 15-20 deg, based on the aftermarket gage I have in the crossover pipe.
