thermostat
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by supernaut, Dec 4, 2005.
  1. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    what temp thermostat are you guys running on your daily driver rigs that also see trail time? I see 160-205 available. My current thermostat opens up at 1/4 up the temp gauge. I wish my 350 ci '75 k5 temp gauge had numbers instead of just lines.
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    180 deg. on 1985 350 ci., four row radiator.:D
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    195* '88 K5, 350tbi, 4.56 gears on 33's.
  4. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    195* 75 blazer with 350, 4.10 and 35's
  5. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    only 195 with tbi. wont go into closed loop with anything lower.
  6. supernaut
    May 2, 2005
    94
    Seattle, WA
    I found that 195* was stock in my '75. I'm going to stick with that. the more I read the more i find that you want to get as much heat as you can in the cylinder's without causing pre-detonation or overheating problems. Apparently this is to make more power. sounds good to me!
    I thought I was getting ahead of the game with a lower temp thermostat. Now I believe it would have been a shoddy excuse to not make sure my cooling system is in tip top shape. I may even experiment with a 205 and see how my cooling system reacts - if i can get that much closer to the threshhold, without going into pre-det etc... then it's like free torque and horsepower, right?
  7. supernaut
    May 2, 2005
    94
    Seattle, WA
    on a side note this is all related to replacing the radiator. I started to pull it and found my trans cooler line fittings to be frozen to the lines. No amount of WD-40 seemed to help. I'm going to cut the old lines up by the radiator and use rubber trans cooler line to make the connection between the old metal line and the new metal fitting/line.
    The parts dude mentioned that the aluminum line was used because rubber lines couldn't stand up to pressurized ATF back in the day. Does that sound right?
  8. dyeager535
    26,979
    Aluminum line? Everything I've ever seen was steel. Using dissimilar metals ensures the parts will never come back apart the way they were designed. If they are aluminum, I'd bet they are a PO mod.
    GM didn't use aluminum because it fatigues easier than steel, the dissimilar metal issue, plus it melts at a heck of a lot less temperature.
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    195 is best the for MPG and all around driving.
    If you want a better performance go with 160 and advance the timing as far as it will go with ot pinging at WOT.
    180 is a good compramise between the two. You can run a little more advance, and still get Ok gas milage
