thermostat
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5blazerus, Oct 10, 2001.
  1. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I am still having problems getting heat from my truck.
    I have a 4core HD radiator and a knew 350 and it has a 195 degree thermostat in it and I still cant get any heat. Do i have to go to small temp thermostat to get heat. I dont even think it reaches 195 becuse the thermostat wont even opean. any Hints.
    thanks colin
    Save the whales Harpoon a fat chick.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Sounds like you have a big air pocket in your cooling system. When you changed the radiator did you turn the heat on when you burbed the system to get all air pockets out?
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    How are your hoses routed? You should have one dump into the rad and the other suck from the manifold. Having the hose dump into the water pump drops alot of cold water on the thermostat and moves the water to fast through your heater core.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  4. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Any time you change the theromstat or flush the cooling system you need to purge all the air out of the system.
    Just fill the radiator, but leave the cap off, start the engine and let it run so all the air gets out of the cooling system. You will see air bubbles coming from the fill neck on the radiator.
    Wait until the thermostat opens and then you will see the level of coolant go down. Top it off and then put the cap on.
    Couldn't be easier!
    74 Blazer
    Zepplin
    Check out my Blazer<a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
  5. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I am having the same problem. I flushed the system and did everything to get the bubbles out. My heater hasn't worked for about a year and I really need it!. What else could it be? Should I change out my heater core?
    Surfing is Life...
