Thermostat
Discussion in '1982-Present GM Diesel' started by Drey, Jul 5, 2003.
  1. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    What would be better for cooling my 6.2 Turbo GMC down a 195 Degree like i have right now or would a 165 degree be better?
    Any Pros and Cons of both would be great, thanks guys
  2. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    I use the 165 in the summer time and the 195 in the winter. I don't if this the corrct way to do it, but it works for me.
  3. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Iowa Julys are pretty hot, and Just driving around I hit 220 if my guage isnt off, I dont plan on doing much winter driving with it so ill prolly just throw in a 165 and call it done
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Throwing in a lower temp thermostat is just a way of covering up cooling system problems. You may have a plugged up radiator, a bad fan clutch, or countless other problems. If GM put 195 degree thermostats in from the factory, they did it for a reason, to help the engine burn fuel more efficiently. If your having overheating problems, find the primary cause of it, dont just throw a different thermostat in there.
  5. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    My fan clutch is good I have already checked that. Im pretty sure my Radiator isnt clogged, I plan on flushing it next weekend if I get a day off from work. My old C10 always ran about 190-200. My K10 runs around 220 very consistantly, hasnt gone above it, I think the reason for it is due to the fact this more has a Turbo Charger and the other didnt.
  6. BlueBlazer
    Feb 15, 2001
    1,940
    Make sure your guage is accurate first of all. Second, the turbo itself wont make an engine run hotter, unless you are constantly under load and using more fuel along with the extra air the turbo forces in. See what flushing the radiator does and give the radiator a good powerwashing, you might be suprised how much stuff is stuck in there if you do any kind of offroading.
